TCMdocs944's Avatar
clutch or slave cylinder? how to tell
Driving home from a long ride.
clutch pedal had been only coming up halfway for many months.
Clutched down and pedal stayed on the floor........
Changed master cylinder....no go..
Could this just be the slave or am I looking at something much more ominous?
Thanks...
Mark
.......(and a big Hiya to all you old guys )
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 06-20-2006, 01:11 PM
Eldorado's Avatar
did you bleed it properly?
was the master "new"? or "new to you" ?
could be slave..
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 06-20-2006, 01:54 PM
TCMdocs944's Avatar
improperly blead.
I am just trying to figure out if there is a definative way to tell without going through the slave and bleeding process. If the clutch is gone I will likely and unfortunately, sell the car.
Old 06-20-2006, 02:01 PM
Eldorado's Avatar
if you didn't bleed it properly, i'd bet that's your problem.
Kyle
Old 06-20-2006, 02:02 PM
Custom User Title
Dave L's Avatar
when one goes the other is ussually close to follow so you might as well do them both.
Old 06-20-2006, 05:21 PM
Eldorado's Avatar
how can you test hydrolic pressure in something that you didn't bleed properly?
if you dont bleed, you have air in your system.
if you have air in your system, you dont have hydrolic pressure.
if you dont have hydrolic pressure, you dont have a working clutch.
Kyle
Old 06-20-2006, 07:00 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Well said Eldo....air compresses, fluid does not. So you drove it with half a clutch for while? Why wouldn't you just fix it properly a long time before it failed so it wouldn't completely fail on you. When the cluth only comes half way up, that's a warning sign from the Porsche Gods that is telling you that you should do some car maintenance. When it's kind enough to give a warning, it's probably best to listen.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 06-21-2006, 07:04 AM
TCMdocs944's Avatar
For the same reason that I don't replace my tires when they are at half tread. Or fill my tank when it is half full.
Sign or no, the clutch is one of those parts that can be ridden till it dies.
Answer to my very simple question....
***If you remove the slave cylinder and look though the site window at the part it pressed on, this piece should have outward(toward slave) tension on it. No tension, clutch needs replacement.*****
For those that need the knowledge in the future.
Old 06-23-2006, 10:12 AM
Eldorado's Avatar
you caused yourself a ton of grief.
just bleed the cylinders.. if you dont wanna listen to advice, dont ask questions.
EDIT:
that sounds bitter. i dont mean it to be.. i was just being very 'matter of fact'..
Kyle
Old 06-23-2006, 01:57 PM
There aren't that many things the will cause the pedal to only come half way up the most common are bad master/slave cylinder, air in the hydraulic system.
Has the clutch been slipping? If it isn't then getting the hydraulics fixed should take care of your problem.
The problem with driving it with the clutch pedal only coming half way up is that the clutch may not fully release when you push the pedal so when you are stoped at a light with your foot on the clutch it will not be fully released causing it to slip and build up heat destroying the clutch.
Current project 80 924
Old 06-24-2006, 09:07 PM
Mark
I had the same problem, pedal half way for a few days then stayed on the floor ,it was the slave, got it replaced for $120.00 total, I had a good, honest repairman.
The man repairing it tried to get a rebuild kit but all parts houses were out. He said going new was about as cheap.
Ed
Ed
1987 944 Porsche
Old 06-25-2006, 01:09 PM
make sure the pushrod is adjusted properly, where it attaches to the clutch pedal. The pedal should only move about .5 inches before you feel it push on the hydraulics. Just loosen the locknut near the clutch pedal and turn the pushrod to adjust it.
87 944S
73 Datsun 240Z
Old 06-25-2006, 06:35 PM
