924 Tach
MY 79 924 HAS GONE THROUGH 3 TACHS. WHEN REPLACED IT WORKS FOR ABOUT A DAY AND THEN IS DEAD. ANY THOUGHTS ON THE PROBLEM?
THANKS
Old 06-21-2006, 10:51 AM
SoCal Driver's Avatar
The tach gets it's signal from the dist side of the coil. Are all the ignition components stock? Or have you changed any out for high voltage aftermarket items?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-21-2006, 01:39 PM
Everything is stock.
77 924 Martini
79 924
80 924 Turbo
Old 06-21-2006, 01:54 PM
Schumi's Avatar
Check voltages on the coil, it shouldn't be over 12 volts, more likely 11.8 or so. I don't know why but if for some reason it wold be high (I don't know why this would even be though) it might fry the tach.
M
Old 06-21-2006, 04:14 PM
Maybe the top of the coil is cracked and the HV is jumping to the dist side. Check it. How do the points look? Or is this the year they changed to a hall sensor???
Old 06-21-2006, 04:44 PM
Schumi's Avatar
if the high voltage was jumping to the dist side that could be potentially dangerous to the motronic computer as the wire also connects there.
M
Old 06-21-2006, 07:08 PM
