Certified Rennwerker
SoCal...re: mount pic
Pic of area mentioned on PM
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Perhaps others can comment on their experiances with after market engine mounts. I replaced mine five years ago with aftermarket. The clearances still look good.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Burn the fire.
Details, 924Sman?
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
Dal
Local driver swore that the balance pulleys were on correctly. Found the top one 180 out. Same vibes around 3,000 rpm. Vibrations eventually cracked the fuel rail.
In any normal situation I would agree but when Istook did the belt drive and all the car was perfect. So when the time came to replace the belts I did so but only replaced the BS tensioning roller and the 2 belts, all else is original from when Istook did them. So if what you say is the case I would have noticed the vibration 4 years ago on the trip up from Texas. Other wise I would take your lead on this and re do the pulleys correctly.
Now you can see why I am perplexed. Thanks! Happy Fourth! Dal
What chart did you use to align the balance shaft pulleys?
I have Porsche manuals. But I just set them according to the tabs and knotches. But wondering if the BS tension roller is a cause, there are 2 types, one has a round hole the other is ogblong, my original one is round but iirc the new one oblong. But still don't think that makes a difference, just grasping.
If the rear cover is supposed to be absolutely tight against the block then I may have where the tab is in the wrong postion. My cover is somewhat flexible moving it fr to rear it can change the position of the tab a tooth or so. But what would help me is a way to keep the alignment and get the tension right because every time I get the tabs in line the tension needs tweaking then it all over again till get lucky! Dal
Hard to get them out of alignment using the marks on the rear cover. The pitch of the belt is a good 1/4". You would notice something wrong. At least you should notice something.
Pitch of the belt meaning the travel the belt noves when adjusting the tensioner?
The distance between the teeth.
Dal, Can you pull the front cover and provide pictures...maybe that would help.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Burn the fire.
Probably both hydraulic fluid filled.
Only way to be 100% certain is to take 'em out. But if you do that, might as well replace with new ones. The opposite side (rubber) may have collapsed. Rubber or Spring centered clutch? How's your transmission mount in the back? 100% certain your balance shaft is aligned correctly?
Good clutch /spring centered. Tranny mounts are in spec. Yep no rubber on the header side mount in the rounded bevel shown on the picture. I am going to place a jack under the header and lift the engine to look for any visable movement/play. If the alignment is off it is because the cover is giving me the wrong tab location. Both pulley notches are absolutely dead on the marks.
Tom ...no pics-no camera. I need to invest in one! Time to dump this motor ans swap for the Ford Falcon st8 6,it wont vibrate! Dal Dal
My 86 944 2.5L doesn't vibrate.
you have an 86, socal? never knew...
my 83 vibrates like a b!tch, but goes away the second i give it some gas (N or 1st or any gear..).. me thinks the mounts need some replacing...
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
83 with and 86 engine. From an automatic.
Thanks for the downgrade offer but I am just going to turbo the straight six and go 3 speed sequential shifter.
Dal
It's your chassis. As there were less than 9,000 of the 924S made I would think keeping it stock has more value than changing out the power plant. Put the turbo in a Tarus and really suprize someone.
