Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
which valve?
Is this an intake or exhaust valve?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 07-03-2006, 01:53 PM
SoCal Driver's Avatar
Intakes are bigger than exhausts.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-03-2006, 02:21 PM
Hey CJ is that small gap between the Intake and Exhaust valve smooth or bumpy. I used a degreeser on my head to get rid of the carbon and after sitting it looked like it had eaten the carbon and turned into a scaley foam. If you're is a lil pitted then im kool, if not that i guess that scale was the aluminum being removed by the degreeser.
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 07-04-2006, 12:57 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Why is that valve so clean looking? New? Looks like a new one just installed.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 07-04-2006, 05:53 AM
Back from Beyond
Gloves? Whenever I have to work on my car, the gloves come off... So to speak.
It's an intake valve.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 07-04-2006, 09:09 AM
Send a message via AIM to TheCooler
Get your toof brush out and start cleaning!
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 07-04-2006, 09:32 AM
Writer/Teacher
CJFusco's Avatar
Well, I am sending out the head to get machined/cleaned and possibly ported (with a new intake valve, of course). I think whatever process the shop has to clean the head would be much more effective than toothbrush/degreaser
Old 07-04-2006, 10:35 AM
fast924S's Avatar
Send a message via AIM to fast924S
Yes that is a intake valve. Yes the shop will have a very good way of cleaning them, usually a hot bath of some really really crazy chemicals. It will come back to you lookin brand new ;-) A nice Port and polish should help alot too since the head is one of the biggest restrictions with making power on these engines
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 07-04-2006, 11:28 AM
Writer/Teacher
CJFusco's Avatar
Would you recommend replacing the valve springs as well?
Old 07-05-2006, 07:33 AM
Aftermarket springs or OEM?
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 07-05-2006, 08:30 AM
Writer/Teacher
CJFusco's Avatar
Ok, how about this:
Talk to me about valve springs
Old 07-05-2006, 08:41 AM
Are you getting tricked out cams?
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 07-05-2006, 08:55 AM
What makes you think that only one valve is bent?
Old 07-05-2006, 08:59 AM
Well Id get new springs if you were getting a cam that required it. Other than that I dont see much point unless youre going to be revving like a maniac. Obviously you dont want to float valves in the '44s
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 07-05-2006, 09:04 AM
You will float valves should you go over the rev limiter or about 7,200 rpm. Usually happens on a down shift.
Old 07-05-2006, 09:16 AM
Writer/Teacher
CJFusco's Avatar
Hugh - I am not positive that only one valve is bent. Only one valve APPEARS to be bent. I suppose I will find out once I bring the head to a shop to be machined/resurfaced/cleaned.
Old 07-05-2006, 12:05 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
CJ...just for future reference, you can look in the intake hole and see a valve stem...that will be the intake valve. If you look in the exhaust port, you'll see the other valve stem...of course that will be the exhaust valve. That's the easiest way to tell the difference.
I think the valve spring question depends on how you drive your car. For the car I'm working on....well let's just say she better not float a valve. If you plan to autox, then maybe something to consider but there are a lot of people here that drive them daily with no problems....just don't overrev the engine and the springs you have should be fine as long as they are in spec which they probably are. The machine shop should let you know if they are not.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 07-05-2006, 12:37 PM
"Take" the head NOT "bring".
You take it there and bring it here.
Examples:
Take the head with you.
Take the head to the machine shop.
Bring the head when you come over to my machine shop.
Did you bring the head with you?
Did you take the head with you?
(The two sentences above is one of few exceptions where both words can be used. Or is it. The first sentence is used at the destination, the second as a question anywhere but at the destination.)
Don't get me started on "got".
Old 07-05-2006, 12:42 PM
Writer/Teacher
CJFusco's Avatar
I don't get you, SoCal. This is a car forum, not the grammar police. Save that stuff for the "Eats, Shoots & Leaves" fan forum. I hold a BA in English and will have completed a Master's in English within the year. I save my formal writing for the 70+ page theses that I have to write twice a year. Forgive me for thinking I can write informally on an automotive technical forum.
So, pray tell, what is the purpose of pointing out bad grammar when it has nothing to do with the topic of a thread? To attempt to impress people? To make others feel bad? Your help in the automotive field is much appreciated, Hugh, but please save me the lectures.
Old 07-05-2006, 12:58 PM
Oh geesh! A BA in English! You should know better. Then the deplorable state of the education system could be to blame. Then maybe not.
Old 07-05-2006, 01:08 PM
