Angry Sticking speedo after instrument light replacement
Hey guys my speedo is sticking after I replaced the instrument panel bulbs. I did disconnect the 3 wiring harnesses and reconnected them ensuring good contact. Anything else?
It sticks at any speed but I can knock on the bezel with my knuckle and it resolves for awhile.
Weird VDO gadgetry behind that instrument panel!
Thanks guys as always!
Brock
86 951 Zermatt
165 mph attained but still not fast enough!
Old 07-03-2006, 11:46 AM
That Guy
Techno Duck's Avatar
Mine does the same occasionally, a very light tap on the dash and it goes to where its supposed to. I never figured this one out.. cleaned the contacts, everything.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 07-03-2006, 12:16 PM
Thumbs up Seems ok now...I removed it again and tightned the grounds and cleaned connectors.
Hey guys if you are dim try this it helps so much. Most of the bulbs were actually ok but very dirty. I replaced the large ones but only cleaned the small ones and all is good.
Brock
86 Zermatt 951
Old 07-03-2006, 09:29 PM
Old 928 Guy
surfdog4's Avatar
to others that might have this problem....
.Definitely try reconnecting the 3 connectors again...I had the same problem after converting my instrument light bulbs to LEDS..the speedometer started acting wierd..turned out one of the connectors (I can't remember which) felt like it was on but it was not quite there..and it's hard to tell at least on mine because there was almost no "service loop" on the wire harness..so you were pushing it on almost blind
After an initial panic..when i reconnected everything (again) the speedometer was OK..but it sure felt connected the first time.
1990 C2 Cabriolet Guards Red
'81 928 Zinnmetallic Project Car (sold) )
'87 944na Maraschino Red Metallic (sold) )
Old 07-04-2006, 07:34 PM
