White and Nerdy
Shadilay. |
Ornery Bastard
Also, while the turbo is technically spinning, it isn't necessarily producing boost at low RPM. My guage doesn't register any boost until about 2,800 RPM if I have my foot to the floor in a high gear. Until then, the manifold pressure is atmospheric or less. As I said, I love my 951 and wouldn't trade it for an S2, but it is less potent below 3,000 RPM than the 2.7 litre 8-valve NA that I had previously.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Non Compos Mentis
Fuel technology has allowed engines to run higher compression without detonation. Old radial airplane engines designed in the 30's run about 6:1, because that was the max before 1930 gasoline would detonate. As octane ratings have gone up, compression ratios have followed, allowing massive performance increases, in both power and efficiency. |
No contest, the 944 Turbo is much faster...
The "S" does have quite a bit more then the normal 944 na, although you have to push it to the upper RPM's to feel the diff...
89 Porsche 944 Owner: AutoFreeFinders.com Online Auto Mall |
