924S/944 tensioning timing belts
We have just changed the timing and balance belts on our newly aquired 87 924S and I have read the numerous posts about proper tensioning. Does anyone have the proceedure for using the old 90 deg. twist method. Where do you apply the twist? If it is the longest run on each belt do you remove the guide strip on the timing belt before testing? If I feel comfortable after tensioning with this method, I'll let er rip. If I have any doubts I'll buy a test gauge. I used the twist method with the 82 924 and never had any problems. Of course, you screw up with the 924S and you're buying another engine.....
Also, I can't read the schematic in Haynes (944 book) for the wiper motor, too small and blurry. Are schematics posted on-line anywhere? The motor will not shut off.
Thx,
Jon A.
Old 07-05-2006, 06:09 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
I've been told that the electrical diagrams are on Pelican here. Because my eyes are not that good anymore, I scanned the Haynes into my computer and used the graphics programs to increase the size. I plan on at some point scanning them all and then using a plotter to print them out.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 07-05-2006, 07:25 PM
tooter884's Avatar
The schematics are in the "Tech Info Center" on this site. To make it easy for you, the link to the wiper schematic is http://www.pelicanparts.com/944/electrical/944_84_5_2.jpg
'83 944
Old 07-05-2006, 07:34 PM
Back from Beyond
If the mototr won't shut off, try disconnecting the plug at the motor and cleaning/sanding the contacts. That fixed my wife's 924.
The twist is done on the long run where the guide bar is. Remove the guide bar first and the idler. There is a photo of this here somewhere. The thread was posted by ccypher.
HTH
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 07-06-2006, 10:30 AM
Thanks guys, I'm on it......
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 07-06-2006, 05:46 PM
