Angry 1988 924s what's my offset???
i want to use 16x7 and 16x8/9 fuchs for my gt conversion but i dont know what offset(s) will fit. early/late 911, 944 turbo, non-turbo? i'm aware of the "86.5 and up offset...will i need spacers? or is there a company out there who makes them ready to bolt on for my specs?
Old 07-05-2006, 04:30 PM
That Guy
Techno Duck's Avatar
Your 924S needs a late offset rim, 52.3mm. However if you are running wide body fenders (similar to that of a 944) you might be able to get away with early offset wheels.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 07-05-2006, 04:41 PM
so when i hear "early offset" does that apply to all models? 911, 944 ...etc
Old 07-05-2006, 04:45 PM
Tam Lin's Avatar
The reason for the introduction of the late "wider track" offset was ostensibly to allow the fitment of ABS, but as this trickled through the different product ranges at different times, you need to look at each model individually. In 944s/924Ss, this means the change to 52.3 mm, and no more Fuchs as standard fitment
924S 1988 KW3 v3, Wilwood brakes, and a diet. Oh and a 3L 16V drivetrain
Old 07-07-2006, 06:11 AM
TY
Old 07-07-2006, 06:59 AM
With out the GT Flares you can get 7x16 front and 8 X 16 rear
Use 225x50-16 tires and 245x45-16 tires
Would need to roll fender. Also will need to quick tie the Parking brake cable to the brake line to clear inner rim. (both sides)
If you put that killer diller GT Kit.. Well. I would think something like 11x16's with 315's in the rear and 275 in front. At least that's the folk lore. Should be same hunting as the 944 with the +2" wide fenders.
FYI the 16" Fuchs can't fit Big Reds Brakes. Would need the 17"
944 85.5+ and Turbo's have ABS offset 52-55mm. Earlier had 23.5 (would need the 25mm spacer with them.
check out "Size Maximus" on this site.
http://members.rennlist.com/951_racerx/
http://www.wheelenhancement.com/index.php?t=Wheels
Factory Wheel Upgrades - Comprehensive Guide with Pics on 944s
Also think 911's before 89 had the same offset as late 944's.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 07-07-2006, 08:59 AM
