LinkBack | Thread Tools | Rate Thread |
PART VII Megasquirt 944 Turbo 315 rwhp / 320 lbft First Dyno Session
Part VI : Previous update
Finally JustinL and I got around to taking the megasquirt 944 turbo to the dyno. It took a number of runs to figure out that my aftermarket knocksensor was wired to by pass my tuning software ........OOOOOPS So I would have ignition retard at 5500 rpm But finally in the last 2 runs we obtained a good baseline of our tuning efforts. By this point the car was fairly warm...... the shop was at 90F but we still managed to produce 315 Rwhp and 320 lbft of torque. For those that like crank hp and torque..... thats ~340hp 350 lbft. With plenty on the table to squeeze out of this setup. I will post the dyno charts once I figure out how to read the format for the images. ![]()
Alex PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi 79' 924 (R.I.P) |
meister member
Thats great! How much boost are you running and hwo do you think that would compare to an engine running the same amount of boost but with the stock computer?
Great project ![]()
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
cold starter
Yep, we spent about 45 minutes chasing our tails because MS2 was telling us nothing changed at 5800, but power dropped by 100rwhp.
The runs were done with an equivalent boost pressure of 16psi at sea level. Up here thats 17 psi over our atmosphere. IMHO that is a pretty conservative tune on Alex's turbo. With the right level of boost and full revs to 6500RPM there should be an easy 340-350RWHP. I forget how ferocious a 951 sounds on the dyno with a big turbo sucking in all the air.
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc. 87 944 n/a: Microsquirted PnP, 284K miles, Fresh engine, Mild suspension upgrades, mildly lightened. |
It was definitely quite a loud roar.
![]() Justin how do I convert these dyno charts? They are in some weird drf format?
What?
I wanna see a 24psi run ;P Can't say much though, my turbo is still sitting on my desk, lol. It does look pretty sitting there though.
Brad Tompkins Current: '86 951 Garnet Red Past: '86 944 16v - '87 951 - '87 951 - '88 951S |
Writer/Teacher
What turbo are you using, ae?
Garnet Red 1986 Porsche 951: Land Rocket Dark Silver 2009 Mini Cooper S ("Mighty Mouse"). Daily Driver Alpine White 1983 Porsche 944 - SOLD, and missed. Guards Red 1984 Porsche 944 - One-time parts car, SOLD. CURRENTLY DRIVEABLE: Porsche[*] Mini[*] |
cold starter
You need the Dynojet run viewer.
http://www.powercommander.com/images/viewer/RunViewer7.0.1.0.zip Just screen capture the image and save as a gif to save space.
WOW love the numbers ;-) cant wait to see what else you can do with it.
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
So is the knocknsense working correctly with MS2 now?
Were you able to add some more timing back in, now that its working?
Stock 1988 951, TT aero wipers |
meister member
was the knock sensor showing voltage? I know mega squirt can ignore knock in the upper ranges of rpm if you choose it to because of regular valve train noise.
Speedy ![]()
Re: PART VII Megasquirt 944 Turbo 315 rwhp / 320 lbft First Dyno Session
However, launching may bring the times up to the low 13's and mph should remain close to 105-108 mph range. Of course we all know Alex would never abuse his car like that!! ![]()
75 914 - Undecided. 80 931 - Gone, but not forgotten. 72 914 - old toy- sold. And a whole bunch of German scrap metal shaped like 924's. Old enough to know better, and stupid enough to do it anyway! |
I might have mentioned this before, but did you ever check out the possibility of using pin 15 on the DME for knock detection?
http://www.motronic944.com/knock.htm It appears to output a perfect signal for the MS, 0 to 5v.
Hey guys,
I had the knocksense wired up wrong..... OOOPS Now its wired right....... It actually works well. Just need to fine tune it further. Ian I am not sure about that pin15. I remember reading it was just noise and did not produce a signal......let alone a 0v-5v signal? If it does then we could probably wire it up on Justins car to log it, I don't have my KLR wired up any longer... Justin are you listening. ![]()
Wow, good numbers so far.
-2002.5 GTI VR6 24V 6SPD -Kalahari Beige 89 Porsche 944S2 -87 VW GTI 1.8 16v -2007 Ford PIMP(free)star ...company car.... -1999.5 Jetta VR6 |
Who can spot where the knock sensor kicks in.
5600rpm?
4300?
3750
meister member
5700 rpm
I almost guessed what WOLF said but I convinced myself that the knock sensor wouldnt be comming on so low in the RPM. Whats the correct answere!!!
