Send a message via AIM to Jer944
speedo cable?
does an 85/2 use a cable for the speedo or is it electric cause mine isnt working right now?
-Silver 85/2 944-
Old 07-07-2006, 05:40 PM
SoCal Driver's Avatar
Yours is electric. Sender is on the drivers side of the trans just over the axle. Most likely you have a broken drive gear in the speedometer.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-07-2006, 05:42 PM
good thats what i thought thanks alot
-Silver 85/2 944-
Old 07-07-2006, 07:45 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Mine was a bad sender. The little magnet that spins around inside was broken in two pieces. Not sure how that happens but it was. I also found one of the three wires on the connector was pushed back too far and wasn't making contact. Worked great after those two problems.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 07-07-2006, 09:12 PM
Does anyone happen to know the part number on the speedometer gear, I have searched the pelican website and cant seem to come across it.
-Silver 85/2 944-
Old 07-10-2006, 09:36 AM
After market.
www.klaindustries.net
US Odometer Gear.
Old 07-10-2006, 11:59 AM
