No Spark issue HELP 8V 2.5L 924S
I have a 924S that is giving me some trouble. I have a signal processed from the DME since the Injectors are firing as required and the DME relay and fuel pump is working fine... The fuel system is all confirmed.
For spark, I replaced the coil with a known good one and replaced the cap and rotor but it seems the non-spark is being caused by a fuse/Computer/loose connection under the dash (where all this is located on the 924S.) Any suggestions would be a great help. It seems I can get it started if wiggle wires/tap on Computer and roll fuses under the dash. But it will cut out and quit when it feels like it. Any advice or help would be appreciated. Aaron atsudds@cogeco.ca |
Check the inside of the computer for soldering issues at the ribbon(grey wire loom).
Dal |
Is it a common issue for the DME to fail... If so I'll try swapping it with another one.
Aaron |
Not often but does. The ribbon is a known area to break.
Dal |
To check that it is a DME problem rather that a wiring problem run a jumper from the batteries positive terminal to terminal #15 (black wire) on the coil and see it it will spark.
SoCal, can I run a jumper and drive it that way in case of emergency?
Does the DME do anything more than provide a 12V supply to the Coil? Like I said, the injector pulse seems to be firing ok. Thanks, Aaron |
The DME provides the ground and allows the system to run. Sounds like you need to both thoroughly check the wiring and if ok, substitute a DME.
Swapped the computer with a known good one... so far so good...
I'll try and fix the old one. Aaron |
If the problem recurs, it may be the ignition switch. I had a similar experience with my 924S and wound up wiring a toggle switch across two of the ignition switch poles. (I was at Sebring for a PCA race.) Five years later, the toggle switch still works.
DME had obvious cold soldier joints on the power transistors. Must have been the problem....
