Cars & Coffee Killer
legion's Avatar
Leaks!
I have a few leaks going on, but the most pressing one is the power steering.
I thought my oil cooler was leaking, but it turns out that fluid is running down a line near it and leaking off of a coil of lines that sit next to the oil cooler. That coil belongs to the power steering system, correct?
5 liters of VVT fury now
-Chris
Old 07-02-2006, 04:09 PM
That Guy
Techno Duck's Avatar
I believe you are refering to the power steering cooler.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 07-02-2006, 05:11 PM
legion's Avatar
I figured out the line from the power steering cooler to the rack is leaking. I can't get at the banjo bolt on the back of the rack.
What size hex key is needed on the banjo bolt. I can't tell if it is 5.5mm or 6mm.
What is the best way to get at the banjo bolt. It seems I can't do it without dropping the crossmember.
-Chris
Old 07-14-2006, 04:52 PM
