Proper volt meter readings?
Hey guys,
I am wanting to check the proper place for the volt gauge to read...
I would think it should read just above the 1/2 way mark or so to show its charging...
89 Porsche 944
Owner: AutoFreeFinders.com Online Auto Mall
Old 07-20-2006, 05:33 AM
Should read about 13.5 volts assuming gauge is reading correctly. Perhaps somewhere in the 14's after starting the engine.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 07-20-2006, 06:11 AM
Thanks much Lawrence...
& Outstanding collection of cars you have there, by the way!
89 Porsche 944
Old 07-20-2006, 07:07 AM
SoCal Driver's Avatar
Need to use a digital meter reading in tenths at the battery terminals. Who knows what corrosion is between the battery and the dash gauge or the alignment of the gauge.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-20-2006, 09:20 AM
Thanks! Like SoCal said, you should check the voltage at the battery with a good voltmeter. Occasionally, my gauge is erratic but I don't worry about it anymore because I have checked the voltage at the battery and it is fine even though the gauge was not reading high enough.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 07-20-2006, 10:28 AM
