-   -   Guess the part! One of the AC switches (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/295009-guess-part-one-ac-switches.html)
pozican 07-23-2006 07:46 PM
Hey guys, not sure which AC switch is, so I figured I'd play a friendly game of ..... Guess this part!
Sorry for the quality didn't have time to bring out the slr -- Taken with a camera phone.
http://img.photobucket.com/albums/v4...72306_1933.jpg
Thanks in advance!
-Alex
pozican 07-23-2006 07:47 PM
Forgot to mention it's in the driver side headlight corner.
Eldorado 07-23-2006 08:24 PM
is it the same as this thing?
what you show is shorter i know, but it might be different on the later car... plus, i cant tell if there's any vac lines coming out of the switch in your pic or not.....
http://forums.pelicanparts.com/uploa...1143152857.jpg
bearone2 07-23-2006 09:12 PM
it's the low pressure switch.
pozican 07-23-2006 10:26 PM
Thanks a lot -- I'll see if I can't get the freon finished....
Porsche-O-Phile 07-24-2006 02:26 PM
Correct - if there isn't enough pressure in the lines it'll "lock out" the compressor circuit and prevent it from engaging. If the freon is low, the oil level in the system is also low. This switch prevents you from grenading your compressor trying to run it with inadequate lubrication.
There is a way to bypass it to add freon and oil to the system, simply run +12V to the compressor clutch wire.
bearone2 07-24-2006 03:40 PM
all you need to do is bridge the two wires going to the switch.
kuehl 07-29-2006 05:15 PM
Re: Guess the part! One of the AC switches
Thanks in advance!
-Alex
here ya go
http://forums.pelicanparts.com/uploa...1154218535.jpg
