Steering wheel on crooked :\
My steering wheel splines do not line up correctly to allow for a straight steering wheel.
It's like 3 degrees off... Which may seem alright, but it gets my panties all in a bunch....
Any ideas?
Thanks guys,
-Alex
My cars for sale, due to move
1986 944 turbo - For sale.
1987 944 N/A - For sale.
Old 11-04-2006, 12:19 AM
You can remedy the problem by using the toe in toe out adjustments under the car. Just be careful and don't mess up the alignment.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 11-04-2006, 03:55 AM
Send a message via Yahoo to Crumpled952
Or you can pull your horn pad off and use a 24mm socket to pull the wheel and straighten it out the easy way.
Rather have a 951 "S" than a girlfriend.
Old 11-04-2006, 06:31 AM
SoCal Driver's Avatar
If the front has been aligned and the steering wheel displaced because of that alignment, then the alignment was done improperly. If the steering wheel is off because the steering link shaft was removed from the steering rack and put back on improperly indexed then take the steering wheel off (as suggested) and re-align it. If the steering wheel is crooked because the front suspension was removed and not aligned after it was re-installed then get a proper alignment. Note: a "proper alignment" involves the use of a special pointed bolt.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-04-2006, 06:42 AM
Right, I tried removing the steering wheel and fixing it the "easy" way, however the splines don't line up...
So is an alignment the only way?
Old 11-04-2006, 09:41 AM
bearone2's Avatar
it might be off a tooth or 2, pull it off and do it again.
"You can remedy the problem by using the toe in toe out adjustments under the car. Just be careful and don't mess up the alignment."
and then you really need an alignment and didn't fix the original problem.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 11-04-2006, 10:31 AM
Worked on mine just fine. The wheel was either a little to the left or a little to the right depending on how I put the steering wheel on. I suspect I did not index the connecting link correctly. A little compensation at the front wheels using the toe in/out adjustments centered it up. Could someone explain technical reasons why this cannot be done to compensate and correct steering wheel position. Seems to me you can compensate a wee bit at either end of the system without messing up alignment.
My tire wear is even, and I did it 50K miles ago.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 11-04-2006, 01:55 PM
