nep75's Avatar
upper & lower balance shaft belt
First I just want to thank everyone for helping with the timing belt question! I'm so glad we found this site. I think my man is going to take a look at the valves - hope they aren't bent.
To review, it's for a 1984 944.
On the same lines as the timing belt question.... Since my man is in there changing it, he was going to do the balance shaft belt as well - His question
"Do the upper and lower balance shafts have to be in a specific alignment when putting the belt on after finding TDC on the crank and cam?"
Oh, and they tried to make it run with out the belt - didn't work so well. lol
Thank you so much!
~ Niki
1984 Porsche 944 (our friend's car)
Old 07-26-2006, 11:02 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
That sound you probably heard was $2k leaving your pocket.
edit: whoops, thought you were talking about the cam belt for a sec there. my mistake
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 07-26-2006, 11:16 AM
nep75's Avatar
joke
(Joke about trying to make it go without the belt. someone had mentioned that in the timing belt post i had.)
Old 07-26-2006, 11:27 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Here is a thread on the topic....hope this helps!
Question on the balance shaft alingnment marks
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 07-26-2006, 11:36 AM
That Guy
Techno Duck's Avatar
Yes, the balance shafts must be in a certain alignment before the belt gets put on.
http://www.clarks-garage.com/shop-manual/eng-08.htm
Double check the alignment of everything, its very easy to get them 180 degrees out of phase. It wont be apparent at idle but when you hit 3000-ish rpms the car will shake like a washing machine on spin cycle.
Porsche decided to remove one of the alignment marks on the sprockets to complicate things, why?? noone will ever know. It was cheaper to make the sprocket with one less "O" stamped on it!
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 07-26-2006, 11:52 AM
SoCal Driver's Avatar
Don't know why you are putting a timing belt on it when the valves are bent. Need to pull the head and replace the bent valves first.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-26-2006, 12:18 PM
nep75's Avatar
thank you thank you
Thank you so much for all the answers!! You guys are so cool! I will show this to my man when we get off work. I'm sure he'll check the valves first, just wanted to get all our ducks in a row. Aquiring the info first before he found himself in the middle of it not knowing about the balance belt.
~ N
cute little red porsche '84 944 (friend's car)
Old 07-26-2006, 12:56 PM
No need to "check the valves first". Pull the head and replace the bent ones. With a stripped timing belt you have bent valves. These are interference engines. If your "man" can't understand that then he has no business working on the car.
Old 07-26-2006, 01:05 PM
Back from Beyond
Heed Hugh.
If your 'man' has to ask about timing the balance shafts, he's not your man.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 07-26-2006, 05:07 PM
As always, I agree with Hugh. It's very easy to go from a 944 that could be repaired to a garden ornament that looks nice but doesn't actually do anything. There are plenty of threads on what "needs" to be replaced and what "must" be replaced when doing timing belt repairs.
Missing out doing either replacing certain parts or not following the repair proceedures usually means the 944 might run, but only last a very short time or won't ever run again and it will be someone else's parts car.
It can be repaired, it just takes time and understanding.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 07-26-2006, 05:56 PM
Granite 944's Avatar
Originally posted by Slam
Heed Hugh.
BINGO!!!..............BIG TIME!!
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 07-26-2006, 06:03 PM
nep75's Avatar
no need
Hey guys, no need for being nasty and insulting. As I said before we're gathering information. Thank you to the ones that gave us useful help.
~ N
Old 07-27-2006, 09:42 AM
Send a message via AIM to hpaulb
Remove head and take it to a shop to have the valves replaced and reseated. Head shaved or checked etc. Replace both belts and check and replace all belt bearings. eary to check. Spin in your hand. If you can hear or feel the bearing, it needs replacing. While there replace all the fron seals.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 07-27-2006, 10:20 AM
Re: no need
~ N
Telling you that you and your "man" are wrong is insulting? Think not. What is insulting is a refusal to listen to experianced advice.
Old 07-27-2006, 11:09 AM
I deleted your PM with out reading it. I do advise you to post any comments you may have here in the public forum. Sending nasties via PM is just imature and childish.
Old 07-28-2006, 10:33 AM
liljon's924S's Avatar
Sounds like some tension in this post. Take a deap breath SoCal!, some people just shouldn't have or "try" to fix Porsches.
"I couldn't find the sports car of my dreams, so I built it myself."
-Dr. Ferdinand Porsche
'87 924S Guards Red, 944 turbo bars, 220lb. springs, Restoration Project even though its and original, 72,000 mile car
'93 325is Red, aftermarket rims, pirelli tires, 95,000 miles
Old 07-28-2006, 12:53 PM
