which oil which oil?
My first oil change is coming up, and I'm really wondering what weight/brand of oil to go with.
I've read synthetics at 5W-40 are the Porsche reccomended way... but what do you guys think?
'84 Porsche 944
Old 08-15-2006, 01:23 AM
20-50 your choice. IMO it doesn't make much difference what brand as long as you keep it full and clean. (Of course assuming it is api certified)
I use the five qt. jugs from walmart. Change the oil every 3-4k, filter every other change. FYI, the factory maint. manual that came w/ the car specifies oil change at 15k intervals.
If I was flogging the car at the track, perhaps I would feel different.
Bottom line, 20-50, clean and full, engine likely to outlast the rest of the car.
MW
PS You should probably lighten up a bit in the dead of winter.
Old 08-15-2006, 05:40 AM
German Aut0haus
B. Elliott's Avatar
I run 15w-40 Rotella-T in everything i've owned. ESPECIALLY flat-tappet motors.
I've never really believed in synthetics too much. The oil will tend to get dirty/contaminated before it breaks down.
'90 964 C4
Old 08-15-2006, 07:13 AM
That Guy
Techno Duck's Avatar
I use 10w-40 for the winter (late october through late march) and 20w-50 for the warmer months. This is in NYC winters where we get a low of usually 0-degrees at the most. Never had problems cranking and starting upwith the 10w40.
The 20w-50 is perfect for when im sitting in staging at autocrosses and its 100 degrees out.. oil pressure does not drop below 3bar. If i was running the 10w-40 it would probably be hovering right around 2bar at idle.
I recently started to use Castrol High Miles and its actually done as advertised and stopped one of my oil leaks. The pan would usually be wet with oil as i am pretty sure the gasket is leaking on the drivers side. No longer goes oil seap out!
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 08-15-2006, 09:03 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
I run Castroil 20w-50 for summer ...and the same for summer-lite. We don't have winters in Texas but if we did, I would follow Techno Duck and switch to 10w-40. I generally pick a brand and stay with it and I've been running Castroil in all my cars including my race cars for a very long time but there are many many good brands. I agree with what was said earlier...if it's clean and full, those are the two most important things. I change mine very regularly and NEVER exceed 3000 miles on oil and I change the filter every time. They are much cheaper than engines, so that's pretty cheap insurance. Engines love new clean oil.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 08-15-2006, 12:12 PM
callmethewander's Avatar
i just top it off every 3rd fill up or so and figure in 3 months i've changed all the oil, my 4 year old filter is prolly so clogged that very, very little dirt gets thru it!!!
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 08-15-2006, 06:11 PM
