-   -   Help I can't get my 84 944 running (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/295906-help-i-cant-get-my-84-944-running.html)
Porsche_951 07-28-2006 10:50 PM
OK i have replaced my speed and reference sensors the bracket and re-gapped them but it still won't start. the negative battery cable is hot after i try starting it. I have no more ideas please help.
mscromer 07-29-2006 07:18 AM
There are way to many variables as to why it wont start for anyone to really help you. You just need to start troubleshooting everything. Two things you need are spark and fuel, so do all the checks to make sure you have those. Then start checking all your sensors, MAF sensor and so on. www.clarks-garage.com would be a good web site to help you with all the different checks you will need to do. Hope this helps.
Eldorado 07-29-2006 08:49 AM
what happens when you turn the key? anything at all?
TheCooler 07-29-2006 09:02 AM
Sounds like he has the same problem as me ....
It sounds like his car is cranking.
Porsche_951 07-29-2006 10:14 AM
it cranks it is getting fuel but no spark.
mscromer 07-29-2006 10:29 AM
Make sure you are getting power to the coil. Then check the coil wire to the distributor then check the cap and rotor. Let use know what you find.
Porsche_951 07-29-2006 10:52 AM
it has power to the coil
mscromer 07-29-2006 11:00 AM
do you have spark coming out of the coil wire?
Porsche_951 07-29-2006 11:07 AM
no i dont think it did i tested all the stuff a few months ago
mscromer 07-29-2006 11:12 AM
If you dont have spark out of the coil and you have the correct power going to the coil then it is your coil that is bad. That is assuming you coil wire is good.
Porsche_951 07-29-2006 11:18 AM
ok i will check that later today
Porsche_951 08-01-2006 09:45 PM
it was the coil it runs now
well when i tried starting it died right away and it will keep dying is that due to bad gas
mscromer 08-02-2006 05:42 AM
Let me see if Im understanding you. You put in a new coil and it runs now but it continues to die after starting it. Or is that what was happening before the new coil? Im a little confused on your last two post.
Porsche_951 08-03-2006 11:01 AM
i replaced the coil and it started then when i give it gas it will die or if i just let it idle it idle bad and will also die. oh and my tach doesnt work
Granite 944 08-07-2006 07:15 PM
Clark's Garage site.
Read it all.
Look at the diagnostic procedures.
Follow them completely, step, by step. Miss one, (no tools, or whatever), well............good luck.
Porsche-O-Phile 08-08-2006 03:01 AM
Probably some vacuum leaks also.
