Well. after the shaking and pulsing when braking. I decided to go ahead and overhall the front braking system for now.
Rotors,Bearings,Seals,Pads, Caliper rebuild, Hoses Since i'm installing new rotors and rebuilding the caliperts.should I A. Paint the calipers and rotor surface that usualy rusts ( the hub ) B. Just install them like so and if they rust/oxidize a lil, oh well If so, any input on the Paint on caliper stuff vs. High temp exhaust/manifold paint ( Could paint on the porsche smbol?). Good rusults, bad?
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. Last edited by AA_Ezra; 08-08-2006 at 10:12 AM.. |
Uhmmm I would paint the hubs/calipers....... maybe black or silver.
The caliper paint they sell at parts stores works really well..... Just try not to rice it up..... (red, yellow) etc........
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
The hubs i'm going to do black, so it matches my black cookies. The calipers, im unsure. leaning towards black/silver... maybe red.
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
That Guy
Defenetley paint the hub parts, basically anything on the rotor which is not touched by the pad... paint it or its going to look like crap. I recommend using any high temp spray paint, makes it easier with some quick masking.
As for the calipers, use the high temp brush on stuff from Duplicolor, available at most auto chain stores including Walmart now. I would just paint them black or silver, anything else draws to much attention to the ugly single piston calipers ![]()
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Install and drive..
Ok maybe paint the caliper, but only a reserved color.
Early 85 944 Factory Cold Air Intake Radial Tires |
Saw the duplicolor stuff at my local wall-mart, Dunno wich color they have tho. I think im going black hubs for sure. and Silver calipers if not black. Off to autozone to get the bearing removal tool. Hopefully by the time i have it all apart my parts will arive in the fedex and ups trucks. And be done today :P. Thanks guys it allways helps to have a lil imput
That Guy
Graham, that was some impressive driving on sunday. If you would be willing i would love for the chance to sit shotgun one run with you.. id like to see what im supposed to be doing behind the wheel! that is of course if its even allowed and you are okay with it.. ill probably have to forfeit one of my runs or something like that.
Im light weight, i promise.. ~150lbs! I wont drink any water before either! Sorry to hijack Jaime ![]()
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 08-08-2006 at 02:55 PM.. |
np. Going to work on the car now.. bought some flat black and some aluminum color hight temp paint 1200 Degrees. And it takes days to fully cure so im also in the process of buying a cheap electric oven so i can cure it ( 1.5-4 hours) and it shall be fanito i hope :P
