Help identifying parts
I bought a 944/951 parts "grab bag" from eBay, mostly for the bolts/nuts/washers and other nickel-and-dime stuff that I really don't want to worry about with my engine build. Well, the grab bag came with some other very serviceable parts like shift levers, tensioner bars, unused oil filters, etc.
Some of the parts I don't recognize, however. Wondering if you all could help. 1) http://forums.pelicanparts.com/uploa...1154486692.jpg Chinese throwing star? 2) http://forums.pelicanparts.com/uploa...1154486874.jpg Some kind of vacuum stabiliser? 3) http://forums.pelicanparts.com/uploa...1154487011.jpg Something having to do with vacuum? 4) http://forums.pelicanparts.com/uploa...1154487056.jpg No idea. 5) http://forums.pelicanparts.com/uploa...1154487223.jpg No idea. |
Pic #1 Fan Cover for alternator
Pic #2,#3 Worth with each other. They are part of the Fuel Evap system. located Near the Brake booster, off to the right on you're 83 944. |
Also, is this a Porsche item? Looks like some kind of light switch, but I can't find any info on it:
http://forums.pelicanparts.com/uploa...1154487738.jpg |
#1 Alternator fan (as previously stated)
#2 Check valve for brake booster vacuum line #3 charcoal canister purge valve with Idle Air Control Valve connector (that is the terminal you jump to set the idle) #4 & 5 Heat shielding for exhaust\catalyst #6 Series 2 944 headlight switch AFJ |
Thanks for the info, guys
| All times are GMT -8. The time now is 04:56 AM. |
