Stripped threads in Waterpump Bolt Holes
As I was installing my new waterpump today I found two bolt holes to be stripped. The bolt just keeps turning, not allowing me to tighten all the way.
I've heard about helicoil kits and I'm probably going to go that route with tapping and installing new threads. Is this the best route for fixing a stripped bolt hole? -Jameson
1986 944 Graphite Metallic N/A 1982 Toyota Corolla RWD 5spd - I miss her dearly 2006 Lib Technologies Jamie Lynn Phoenix 157w Blue Girl 1999 Lib Technologies Jamie Lynn 156 16" 968 Wheels-w/Kumho Ecsta 712-For sale or trade |
I used a helicoil on my A/C compressor, and it worked GREAT!
In fact, I actually found a helicoil that my dad bought in '85 and never used. Dunno if they are any different, but I have had no problems
My cars for sale, due to move 1986 944 turbo - For sale. 1987 944 N/A - For sale. |
Helicoil will work fine.
Its not fun with the engine installed.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
German Aut0haus
Also, check out the Timesert thread repair kits. More pricey than a standard helicoil kit but more reliable.
Timeserts were the only ones we would use in my old machine shop.
'90 964 C4 |
Helicoil is not the best. There is an insert with an outer thread and an inner thread. The hole is drilled bigger and this "insert" is then screwed or bolted into the hole... its a type of hollow tube. The inside of the tube has already the correct thread. I am not sure if the Timesert, mentioned by B Elliot is the correct term.
All the best
1983 944 RHD Original. Uses all my spare cash! 1947 Morris Sold 1972 Benz Sold 1975 Benz Sold 1976 Benz Sold 1977 Benz Sold |
That Guy
Helicoil worked for me with some stripped bolt holes for an oil pump. However the big problem is clearance as you need to be able to fit a drill in there to enlarge the hole. Unless you have a 90 degree bend type drill you will probably have to take the radiator out. Its imperitive you drill straight on with the helicoils.
Also if you do decide to use the heli coil, make sure you are aware of the depth you are drilling into, meaning measure how deep the threads go and dont drill beyond that. You dont want to drill into a cylinder now .Its pretty incedible how soft the aluminum block really is.. great care must be taken!
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 08-10-2006 at 08:35 AM.. |
You do have to remember that the block wall where SOME of the water pump bolts go is only 1/4" thick which will make the bigger inserts more difficult to put in than the helicoil. I'll put a picture up tonight to show which ones. As Techno Duck already mentioned, the cooling chamber is behind there and beyond that is cylinder 1 but there is about 1/2" gap in between.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
I'll take extra caution when I drill the old threads. The last thing I want is a cross-drilled block. Thanks for the feedback. -Jameson
German Aut0haus
May have to just use a regular Helicoil because of the space limitation.
'90 964 C4 |
Certified Rennwerker
Are the threads completely wiped out and or do you have any good threads in the bottom of the hole?
If you have just crossed threaded and have good threads in the bottom you can back tap it. What this does is start the new threads at the bottom good threads and as you back the tap out it cuts new ones or straightens out the marred threads. A back tap is basically a "mandrill tap" meaning it is tapered and can be expanded enough to re cut threads. No inserts needed, no drilling. And no concern on bore depth in the block. Consider ALUMINOY sp? as a filler then retap at the OE size. Won't be too hot to weld. Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Jimbo,
Just did the Helicoil deal today on one waterpump bolt that was stripped. Def. very easy to do and easily torqued down with zero issues. As others have said watch how deep you go with the drill bit. |
I believe that our WP bolt dimensions are the same from a turbo to a N/A but it'd be best to make sure. Last edited by ELLSSUU; 08-25-2006 at 02:04 PM.. |
