konan's Avatar
85' 944 clutch?
I think the clutch is gone,here's what happened......heard a pop and then scraping noise......when I engaged the gear and let out the clutch I hear scraping under the shifter.Ideas?
Old 08-24-2006, 10:29 AM
Burn the fire.
Brando's Avatar
Could be many things with what you have described. Does the car move at all when in gear? Does it make a huge CLUNK-CLUNK when accelerating and decelerating?
Will you be doing the work yourself or have a shop do it?
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 08-24-2006, 11:21 AM
konan's Avatar
Doesn't move at all.......I will be doing it myself....it sounds like maybe that rubber on the clutch disk went out.......have you ever experienced that?
Old 08-24-2006, 12:16 PM
Burn the fire.
Brando's Avatar
If the rubber center failed there are still three metal "safety tabs" that allow the car to still be driveable in the event of a broken rubber center. It is possible you sheared the tabs as well (could be the grinding noise?).
When my rubber-centered clutch failed I drove it on the safety ears for about 500 miles. Maybe I got lucky. I've seen rubber centers fail and the metal ears shear in less than 100 miles after. It's a gamble and just meant to get you home.
My best suggestion would be to get it to someone who can get your car on a rack and inspect it. Or you can get a few jack stands and start pricing a spring-centered clutch kit
Old 08-24-2006, 05:57 PM
konan's Avatar
It's something in the clutch.....do you have to pull the transmission?
Old 08-24-2006, 07:22 PM
Burn the fire.
Brando's Avatar
Basically...
http://www.clarks-garage.com/shop-manual/clutch-01.htm
That will just about cover everything for a clutch replacement.
Old 08-25-2006, 06:54 PM
konan's Avatar
Yep,you do........
Old 08-25-2006, 10:04 PM
Don 944 LA's Avatar
I drove on the tabs for about a year
Sounds as if something around that area is falling apart ( grinding noise ).
have you gotten up under it yet to take a look ??
Don
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 08-26-2006, 08:43 AM
konan's Avatar
Yep,ended up being the spline shaft going into the clutch disk wore down and it was just grinding instead of turning.......does anyone have any knowledge of getting the shaft out of that tube?
Old 08-26-2006, 07:08 PM
meister member
speedracing944's Avatar
You may be better off just purchasing a new used torque tube if the splines are shot. How bad are the clutch splines? You may want to install a new clutch while you have it apart.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 08-26-2006, 09:08 PM
konan's Avatar
The funny thing is the clutch looks ok.I was trying to save money by just replacing the shaft......
Old 08-27-2006, 06:12 AM
