Bucking on deceleration
Is there a rubber piece in the transmission mount that can deteriorate or delaminate? My car now bucks and makes
grinding noise in the lower gears when I decelerate . Never used to, was always smooth as silk.
Jeff
Jeff Laurence, '87 944S
Old 09-23-2006, 12:04 AM
Eldorado's Avatar
not sure about the mounts..
is this if you down shift?
if so, is it when you go into the gear?
or when you clutch out?
does it do it when you just take your foot off the gas?
or when you take your foot off the gas and brake?
more info
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 09-23-2006, 12:10 AM
In the lower gears, when I just let off the gas--- It makes such a
violent buck that I immediately push the clutch in. Will have a look underneath today if I have weather on my side.
thanks for the reply,
Jeff
Old 09-23-2006, 07:04 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Check the fluid in your transmission for metal shavings.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 09-23-2006, 02:20 PM
gtroth's Avatar
When the rubber center goes in your clutch you'll get a "clang" on accleration and deceleration, and when you put it in gear. And they'll be alot of drivetrain backlash that might cause some bucking. But grinding? Probably something else (R&P?...).
1995 993C4 guards red
1988 944S alpine white
Old 09-24-2006, 04:02 PM
