tnporsche's Avatar
low power can remove #1 & 4 inj plug, no diff
Well I got it running now. After months of figuring out finally it was the screw for the ref sensor.
Today i did the first test drives. It seems very low on power and may have a intake leak on number 4. (likely contributing)
(It takes 1/4 mile to get to 50mph)
Besides the intake leak what are some other things to look for in a low power?
New spark plugs, cap, rotor, coil
Compression good
New fuel filter checked psi, good
1988 944 Automatic (I know, I know, but it came this way)
Lowell
1988 944 Red Project car (Now daily driver, Daughter's to school ride)
1983 944 Grey NEW Project car
http://www.pelicanparts.com/gallery/tnporsche
Old 09-02-2006, 08:05 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
If you damaged the reference sensor putting the engine in, you may have damaged the other sensor as well. Check that. I would also look for all vacuum leaks and check your throttle position sensor. clarks garage has a detailed checklist for that.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 09-02-2006, 09:33 AM
tnporsche's Avatar
Porsche Crest
It turned out that # 2 and # 4 intake gasket had huge! leaks. I have installed new and just in-case all new vac hoses.
With engine idle, removing # 1 and # 4 injector plug causes no difference in running.
I had already tried soaking the injectors.
They have 12v with key on.
A steady noid light with engine idle. (I cant check 2 or 3 because it wont run on one Cly for me)
3 Questions
( Is the noid light supposed to blink?)
What else should I check?
Could ref sensor still be out of adjustment? (or would it not run at all if out of adj)
Lowell
Old 09-14-2006, 12:10 PM
