Fuel filler hose.
Can anyone tell me if part number 944-201-309-00 the Fuel filler hose, the piece of flexible hose that joins the Filler to the tank is something that can be obtained from any parts store?Autozone or Napa.
Is it standard hose and what should I ask for as the Ghetto stores i've been in recently look at me blankly. Thanks. Would something like this of the right diameter be fine?
89 944 Turbo 115k miles, Stock 96 Range Rover 4.0 SE 130k miles. 84 944 170k miles, FR Wilk Chip, Sold. "Don't listen to me, I dont know what i'm talking about" |
Think it's a dealer item.
What's wrong with yours?
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
You're right $108. Mine leaks.
Usually it's the tank that leaks. Cracks on the top. Or someone put screws through the cargo deck into the fuel tank.
Hmm ok, I'll have a closer look, its just such a PITA to see anything. There are no screws through the top though.
Are all years and all models of 944 tanks susceptible to cracking?
