drivetrain "backlash"
let me see if i have what's known as "backlash".
when i go from power-on to power-off in first, second, and sometimes third, it's accompanied by a sudden jerk. similarly, when i put the power back on, it's accompanied by an even bigger jerk in the drivetrain.
do i need to replace my clutch too?
'84 Porsche 944
Old 09-09-2006, 01:07 PM
SoCal Driver's Avatar
Yah! It's der klutchanting.
It's also called wrap up. Keep jerking it back and forth and there will be no clutch real soon.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-09-2006, 03:24 PM
16 labour hours.
How much is this gonna cost at a shop?
Speaking of shops... can anyone reccomend one within easy limping distance of Champaign, IL?
'84 Porsche 944
Old 09-09-2006, 05:49 PM
Yeah there is a shop on Springfield just west of 1st street called Ricks Automotive. They do a lot of work on 944s (they actually support a couple track cars). They charged me a pretty good rate too. Both legion and I have had work done with them. Did you have your 944 on campus two years ago?
'84 944, '05 GTO
Old 09-09-2006, 07:27 PM
No i didn't have it on campus two years ago.
'84 Porsche 944
Old 09-10-2006, 12:17 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Clutch...please......Come on guys you know it is due to our very torque laden powerplants!
If the shop suggested falls through there is Eurosport in Bensonville, I will personally guarantee the work. Ask for Steve.
Happy stationary motoring!
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 09-10-2006, 07:28 AM
Zero10's Avatar
Send a message via ICQ to Zero10
Have it checked to see if it is the clutch. I have found that 944's are rougher than the average car when transitioning on/off the throttle. Some jerk is normal.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 09-10-2006, 08:37 AM
I agree with Zero, basically. If the clutch is the original rubber-centred one, then yes, I'd think that too much backlash means it's dead. But the spring-centred clutch is less forgiving and more 'jerky'. I upgraded to the latter and the car is a little jerky on and off throttle in lower gears.
Is there a lag between the time you hit the gas and the time you get the jerk?
'84 944 - new-to-me DD!
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project - forever incomplete.
'80 924 - spouse's yellowjacket.
Some wrecks and a 924 racer.
Old 09-10-2006, 09:19 AM
Burn the fire.
Brando's Avatar
Labor rates may vary from shop to shop. Find the most honest tech in your area and stick with 'em.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 09-10-2006, 09:55 AM
I want to say yes.
'84 Porsche 944
Old 09-10-2006, 11:30 AM
Haha I'm struggling to figure out how to get it 1 mile, let alone 150.
'84 Porsche 944
Old 09-10-2006, 11:41 AM
idontknow
Senior Member
I posted this in another article but it might help
Check the CV joints. Jack the rear end up, you only need to jack up one side to test. Put the car in 1st gear and rotate the rear tire back and forth. hold the CV joint /driveaxle in one hand and feel the difference of movement. If a/many cv joint/s are bad, you'll probably hear the clunking but definitely feel a difference in movement. eg. CV joint moves, drive axle does not = bad CV joint. If the CVs are good and you think it's the ring and pinion, pop the little inspection plug from the forward nose cone of the tranny and rotate the tire again. If the driveline shaft doesnt move but the wheel does, it's in the tranny. If the driveline shaft does move, it's not in the rear end.
Was looking for another post-In neutral try and twist drivetrain through nose cone and if you get like a 45 deg twist either direction you should feel if clutch rubber is gone-Socal is inevitably correct - Paul
Hope it helps. I had all 4 CV joints bad when I got my car. The car made a clunking noise every time applied power or shifted. Didn't think too much of it. Eventually one of the CVs started making BAD clunking noises whenever the car was rolling. After replacing the CV joints I found that the clunking action was also eroding the R&P. $320 for 4 new CVs and $1200 for a rebuilt tranny and I/my bank account have learned a very valuable lesson.
Hope it helps
83 - 944, daily driver
62 - VW Karmann Ghia, never ending restoration
94 - Merc Sable, wifes barge on wheels
Old 09-11-2006, 03:17 AM
I want to say yes.
You can say yes. It's okay, we're all friends. I sometimes talk to my car when we're alone together. Sometimes I'm monosyllabic...
If there's a lag then it's probably clutch time.
Old 09-11-2006, 08:07 PM
Schumi's Avatar
I get a small jerk when I suddenly let off throttle in 1, 2, and 3. It feels like I hit the brakes, but it's just let off. I also have a knock or cluck when I let the clutch out out low speeds and don't rev match. I figure it's the rubber center knocking. The clutch is still very very strong though. Stonger than my other veicles. So I'm living with it.
M
Old 09-11-2006, 11:00 PM
The knock is the 'ears' on the clutch that act as a fail-safe so you can limp home after the rubber centre fails. Eventually they'll shear off and you'll be walking. I'd have that thing out and changed soon if I were you. Just MHO, though...
Old 09-12-2006, 09:16 AM
