84 944 reverse light switch
Can someone tell me exactly where the reverse light switch is located?
Manual tranny Last edited by P0WER; 09-14-2006 at 10:00 AM.. |
Two Pin Black Plug on passenger side Tranny. About half way up on side facing gas Cap. Follow wire that come from up high under Gas tank by fuel filter.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles |
Should be close to this 968 Tranny
