-   -   Control arm bushing question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/305557-control-arm-bushing-question.html)
TNT25169 09-21-2006 10:57 AM
I know to put new front control arm bushings in you need a press, would it be possible to use a vice or can you not get enough pressure? And how hard is it to remove the old bushings?
JRMock 09-21-2006 11:38 AM
Unfortunatly the OEM rubber bushings can be quite challenging to get in and out. I've used a vice, and various deep well sockets to push them out, and act as a backstop for the A-arm. Lighter fluid works well as a lubricant, and will evaporate fairly quickly. Removing them envolved cutting off the rubber shoulder on one side, and punching it out the other.
I have the Delrin two-piece bushing, much easier to install, (but quite a bit more expensive) but it is a race car.
good luck
JM
:cool:
TNT25169 09-21-2006 12:01 PM
Thanks for the help. That's exactly what I wanted to hear.
arbita1 09-22-2006 05:04 AM
Weltmeister makes replacement bushings for this that are very easy to install.
However there is some debate as to how good they are. I have them and autocross and have had no problems...Yet!
rb101 09-22-2006 11:15 PM
I rebuild my front end about 1 year ago and used the weltmeister bushings, no problems so far. I rebuilt the ball joints, strut inserts, tie rod ends, sway bar bushings.
Dark Skies 09-23-2006 07:03 AM
Putting in the new bushes is a piece of pi$$. Thoughly clean the insides of the bush retainers to help ease it in. Place the bush in position and then get a long bolt threaded down the majority of its length (or a screw) and put it through the steel centre of the bush. Place a socket on the other end - just big enough to allow the end of the bush to enter it. Put a nut on the end of the bolt / screw. Put the head in a vice and tighten the nut with a spanner against the back of the socket until it draws the bush into the control arm retainer. Doddle. Takes a few minutes per bush.
