arbita1's Avatar
Car Not Starting
When I turn the key...nothing happens. The engine doesn't crank. Plus I hear this buzzing/humming sound coming from the cigarette lighter area.
The battery is fine. It has 12V and all electrical items work.
I've tapped on the DME and banged on the starter.
Any ideas????
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-19-2006, 05:53 AM
That Guy
Techno Duck's Avatar
Have you checked the ignition switch?
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 09-19-2006, 05:59 AM
arbita1's Avatar
No. Is there a procedure to do it?
Actually I see Clarks has a procedure. I'll check that out.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-19-2006, 06:06 AM
Sometimes a bad connection at the battery terminal can cause a vehicle not to turn over. Electrical things that don't require much amperage will work but starter will not turn the engine over. Try cleaning battery posts and cables where they connect to battery.
This can be tested by turning on the interior light. If it goes out (or nearly so) when you turn key to start, a bad connection is more than likely your problem.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 09-19-2006, 06:07 AM
Also, check the connections at the starter. They can get messed up and need cleaning sometimes.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 09-19-2006, 07:08 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
The key is to check everything at the starter. Do you have 12 to 14 volts on the large post of the starter? If not, clean battery cables (both ends) and try again. If you do, then check the small wire while the key is in the start position. If not, the problem is probably the ignition switch. If you do, then grounds are the problem or the starter is bad.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 09-19-2006, 08:57 AM
Have you tried to push start it??
86 944 daughters
88 944 step-sons
07 Ranger 4x4
Old 09-20-2006, 10:15 PM
arbita1's Avatar
Ok...so got around to checking this out this morning.
The batter is fine. It is about 65% charged with over 12 volts. When I try to start the car, the interior lights do not dim.
Then I did the starter check. Connected two leads to the starter, touched them together...and all I got was a spark from the leads. The starter didn't turn.
So does that mean the starter is bad? If so, how do I know if it's the solenoid so I don't have to replace the whole thing?
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-23-2006, 07:32 AM
Eldorado's Avatar
what gague wire did you use at the starter?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 09-23-2006, 12:31 PM
arbita1's Avatar
I'm pretty sure I used 12 ga. wire.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-23-2006, 01:22 PM
arbita1's Avatar
So I decided to look into the buzzing noise inside the dash. I took off the panel above the glove box but I could not tell what it is. Seems to be deep inside there. I'm thinking it's HVAC related...and has nothing to do with my No Start issue. When I put my finger over the tube that brings in air to determine the cabin air temp, the buzzing gets quieter.
So any opinions before I drop $ 150 on a new starter. Performance Products sells the solenoids for $ 50. I'd rather go that route...but how do I determine if that is the problem.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-23-2006, 02:21 PM
If the solenoid is bad it will usually (not always) make a clicking sound. You probably need to replace the starter although the local auto parts store will check it for you.
Tom
Old 09-23-2006, 02:33 PM
arbita1's Avatar
No clicking sound.
I wish you had given me that idea earlier. I could have done that today. Oh well.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-23-2006, 03:11 PM
I would strongly suggest you take it to the auto parts store and ask them to test it. That's the easiest way. I would also suggest that you buy some dielectric grease to put on the wires when you bolt them to the new starter or back to your old one. Clean the terminals on the wires real well with a wire brush or some similar tool to make sure you are getting good contact there as that is the main power for the car and very critical.
Tom
Old 09-23-2006, 11:05 PM
arbita1's Avatar
I did this today at Autozone. Starter failed all tests so I guess it's bad. Thanks for your help.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-24-2006, 05:03 PM
