-   -   Turn Signals Not Working (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/307108-turn-signals-not-working.html)
arbita1 09-29-2006 05:44 PM
Each time I fix one thing...something else doesn't work.
As it says in the title...my turn signals don't work. I flick the lever up or down and nothing happens. The outsides and inside lights do not light up.
How do I fix this.
roadierfl 09-29-2006 07:39 PM
You might want to check the fuses and then the flasher relay before pulling apart the dash to get at the switch
Panzer909 09-29-2006 09:22 PM
Yep - sounds like a relay.
If you were to turn the signal switch and it remained on without blinking, that means a bulb went out. Nothing usually is a fuse or relay. Easy fix.
arbita1 09-30-2006 04:44 AM
I just tried the hazards and they work. So I went to try the turning signals...and now they work.
What's up with that???
PS...how do you check the relay?
