Ignition Coil
Hey guys, quick question, does it have to be Bosch (944-602-115-00-M14) ignition coil ($117 from Pelican). Or can it be other aftermarket ignition coil (hopefully cheaper kind).
Dan
Old 10-11-2006, 03:46 PM
Aftermarket will work.
http://www.lindseyracing.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LR&Product_Code=LR-MSD-8222&Category_Code=944COIL
Old 10-11-2006, 06:22 PM
Dtchy's Avatar
I have an MSD blaster 2 with ballast resistor and I'm very happy with it...
They're approx 50 bucks.
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 10-12-2006, 12:56 AM
Did it require custom plug wires or will stock plug in and work?
Old 10-12-2006, 05:28 AM
SoCal Driver's Avatar
How do you know the coil is bad?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-12-2006, 10:31 AM
you test it as per Haynes manual
Dan
'84 944 - Under construction
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 10-12-2006, 02:37 PM
And you found values out side of these?
Term 1 to 15 = 0.4 - 0.6 ohms
Term 1 to 4 = 5 - 7.2 k-ohms
Old 10-12-2006, 03:59 PM
