Why do Parking lights Stay on when I turn car off?
This is my second question of the evening.
When my turn signal is left on and I turn off the motor, the lamp remains on until I put the steering column turn signal switch to the center position. ALSO, when the Headlights switch is left on and I turn the ignition off, my parking lights stay ON. WHY???? Again, THANKS!!! 1983 944 |
Mine do the same...
I don't think it's a flaw in the car, I believe it was engineered that way. Not sure why I guess...
My cars for sale, due to move 1986 944 turbo - For sale. 1987 944 N/A - For sale. |
its a european thing.
1995 993 C2 |
Thanks. Now I am not alone with this mystery!
Let's go shooting.
These are safety measures built in for short term parking. It's so's you're less likely to have your car run into when parked up in poorly lit areas.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas 1991 944 (automatic) 2.7 litre 16 valve na and pas "I have only five words for you: From my cold, dead hands." |
Streets in Europe are really narrow, and the idea was to leave one side or the other on if you were poking out a bit, so you don't get scraped.
Lot's of cars lights stay on when the ignition is off, but the 944 kills the headlights. It's all designed that way.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Virginia Rocks!
when I fist found out about this, I tried it on my 2004 BMW. That does it too. Pretty cool feature.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
so u go and put the turn signal in its proper spot
88 928 S4 Black, Black and Grey Interior Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover. Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red |
Mercedes does the same with the main headlight switch. Turn it CCW one click and only right side parking lights come on (ignition off). Turn it CCW two clicks and only left side parking lights are on. Turning switch CW does nothing unless ignition switch is on.
Leaving only one side on uses less juice. It's a European thing.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
I thought I had read on this site or rennlist that leaving those parking lights on could result in burning up the wiring harness? Anyone else read that?
1987 924S 2000 Camaro Z/28 |
Yeah, it's about parking in narrow Euro streets; common practice is to park with one side of the car up on the sidewalk, straddling the curb. You can leave the one side indicator on to mark the outside of your car so hopefully no-one hits it. 924's have been like this since day 1.
I wouldn't be worried about burning up the wiring harness with stock lights.
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
