Wipers and headlights
I recently moved to Germany and figured the proper thing to do was to purchase a 1987 944, however it appears to have a couple of issues. First, the intermittent wipers don't work, unless the headlights are switched on, in which case the wipers won't stop working. Anyone heard of anything like this before? I assumed the headlights and wipers were totally autonomous systems. Also, the threaded plastic fitting that attaches the small expansion tank hose to the radiator is broken off in the radiator. The best bolt extractors the master race have over here won't budge it. Any ideas on extracting a plastic bolt from a plastic radiator?
Old 11-09-2006, 05:26 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
They do share the same switch on the steering column...maybe someone hooked it up incorrectly. I'm not sure where else they would be connected either.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 11-09-2006, 07:28 AM
callmethewander's Avatar
what's autonomous? is that german for car something?
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 11-09-2006, 12:08 PM
bearone2's Avatar
the fitting for the expansion tank can be tuff to get to in the car.
it's not all that tight and probably corroded some.
there's also a knob next to the a/c switch that controls the speed of the intermittent wipe.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 11-09-2006, 02:41 PM
No autonomous is very much English meaning separate or different systems. He was trying to say that the wipers have no common parts with the headlights.
Tom
Old 11-09-2006, 08:45 PM
