F/S: 85.5 944 n/a
1985.5 n/a 944 5speed.
interior:
cloth sport script seats, overall clean interior. new ebay special steering wheel, guages just cleaned up/inspected/replaced odometer gear, blue LED dash lights, climate control WORKS, although a/c isn't charged, rear hatch leaks a little like usual, pioneer cd player, 4 new eclipse 4X6 speakers, new cassette tray/lid. New Schnell short shifter, although the shift lever is worn out as usual, so there is play. Sunroof is just fine, but it only latches down on one side. It looks like the passenger's side 'catch' is wore out on the lid.
exterior:
Paint is suprisingly nice! Towards the upper rear panels it is sun-cracked, no rust at all, battery tray is perfect, but the lower part of the car has a decent amount of rock chips. The front is the ugly part. I replaced the center nose. The headlight motor tested out fine, all lights work, but the fuse is pulled for the motor. I was told $200 bucks will have the frame work done and the body panels all lined up ready for a little paint. The fog light lens' are popped. $30 each.
suspension:
Stock, Steering is nice and tight
Engine:
There's a connecting rod hanging out of the oil pan. MAYBE the block is good, but I know for sure the head is fine. Other than that, I traced all wiring in this car thoroughly from a previous battery drain, replaced the battery and cleaned up all connections. You won't find any electrical demons in this baby anymore. I just had all the front seals/belts/rollers replaced 3500 miles ago, although that probably doesn't matter. New cap, rotor, Jacobs wires, NGK plugs. I even ran Amsoil 20/50 in it. The transaxle was just serviced at time of front end service. Also fresh front end alignment.
Overall the car doesn't need all that much more to make it in life. I'm just really pushed to my patience limits from fixing it all up and then having the engine go.
I HAVE ALL SORTS OF MISCELLANEOUS PARTS HERE AND THERE THAT WILL GO WITH THE CAR.
I need $1000 out of it. No less. Thanks
1985.5 944 black/black 5 speed
http://img142.imageshack.us/img142/3043/elisdn1.jpg
Old 11-07-2006, 06:34 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
Man.... If I was closer I would be there right now with a trailer. I dont exactly have a week to jaunt out to NE and back. Good luck on the sale.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 11-07-2006, 07:08 PM
EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
i dont want to buy the car but can you snap a picture of the oil pan?!
1995 993 C2
Old 11-07-2006, 09:19 PM
Old 11-08-2006, 07:01 AM
You've got a PM!
Old 11-13-2006, 05:51 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Not too far from me but needing a new engine and frame straightening for a grand. Too much for me to snag up otherwise I would be there in person in less than 2 hrs.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 11-14-2006, 01:36 AM
sca037's Avatar
Too bad you're so far away, as if perfect the P-cloth sport seats alone are nearly worth the price you're asking!
Brian
'85.5 944 (sold and will be missed)
Sport seats, LSD, sways, 7 & 8" Fuchs
Old 11-14-2006, 10:02 AM
