white944cup's Avatar
Rear hatch opening
I am having a problem that I have not seen posted on this forum before. I was driving back from the Gator game today and I noticed my rear hatch was open. I stopped and closed it, and resumed driving. A couple of miles later, the hatch was open again. The switch does not appear to be stuck, but the hatch opened on its own 3 more times before I got home. Tomorrow I will pull the switch and check it, and also check for bare or crossed wires. Has anyone out there ever had this same problem? I have not had any previous problems with the hatch or the switch.
Old 11-18-2006, 05:31 PM
Rrrockhound's Avatar
Check your latches first. They're adjustable.
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 11-18-2006, 05:49 PM
I had this problem also...I've had luck putting the key in and wiggling it a little..The latch wasn't going all the way by itself...
1986 944/NA
2004 Yukon on 20's (Bling Bling)
2005 Durango Hemi
Old 11-18-2006, 06:33 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
You could always unhook the wires to the motor to make sure but it's probably not an electrical problem. Probably the latch mechanisms. I had to regrease mine periodically to make sure they slide properly.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 11-18-2006, 11:20 PM
I have this problem right now as well. I've gone through several hatches and the most recent doesn't like to stay down. For just a temporary fix I un-latch one of the hatch struts. I will adjust the latch after some PB Blaster soaks in there.
1986 944 Graphite Metallic N/A
1982 Toyota Corolla RWD 5spd - I miss her dearly
2006 Lib Technologies Jamie Lynn Phoenix 157w Blue Girl
1999 Lib Technologies Jamie Lynn 156
16" 968 Wheels-w/Kumho Ecsta 712-For sale or trade
Old 11-18-2006, 11:38 PM
Thanks for the help and ideas.....I opened the hatch and looked at the latches and they both appeared to be rusty. I sprayed them with WD40 and opened and closed the hatch a few times. Took it for a ride and the hatch is now staying closed. Hopefully problem is solved.
Old 11-19-2006, 10:23 AM
The hatch has Mushroom shaped Plugs. The trunk has Females. Mushroom wear the forward side down. Females also goes outta round. I think if you Rotate the Mushroom 90 or 180 degrees would help. But I have never tried this. May need to swap left and right ones if they are non-symetrical.
Let us know if this works.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 11-19-2006, 10:34 PM
