EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
Plastic overflow fitting half stuck into radiator
Well, as i was letting the car idle in the garage listening for the new belt whine, and reving it a bit, i was able to get a sight on the small coolant leak thats been bugging me... its infrequent but its there.
it appears to be coming from a fitting on the top drivers side corner of the radiator. just above the hose that goes to the top of the block. the best i can see this is the overflow line...
i tapped the suspect fitting and the plastic fitting came free from the radiator with just the touch of my finger.
there was just under a 1/4" of thread left on that fitting and judging from the look of it, the remaing threads are STUCK in the radiator!
luckly, i was able to gently screw it back into place and so far its not leaking, and its holding pretty tight on what few threads are there.
how do i go about extracting the reamaing threads from the radiator?
then i guess it should be easy enough to just order up a new fitting from pelican.
as always, thanks in advance,
Kevin
1995 993 C2
Old 11-28-2006, 04:32 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
You can use an ez-out to get the rest out if you can get it. They get stuck in there pretty tight. Make sure you order a new sealing ring to go under the new fitting.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 11-28-2006, 05:28 PM
EMBPilot's Avatar
found the parts...
944-106-927-00-M100
944-106-928-00-M100
thanks for the help tom, i'll give it a shot this week.
EDIT FOR COMPLETION:
thanks for the help guys, i ended up using a small EZ OUT and it came right out, easier than suspected. i used a nylon seal from a local store with a new adapter from pelican and it all went back together just fine.
1995 993 C2
Old 11-28-2006, 06:26 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
you can heat the end of a flat-head screwdriver enough to melt a bit of the plastic... let it sit in there until the plastic re-cools, and then gently unscrew the piece out of the radiator.
the method works... ask how i know
lucky it's an easy fix, and not too expensive
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 11-28-2006, 08:12 PM
