xupkid2's Avatar
Hot Dip Block
Wondering if anyone has hot dipped a 944 block. I want to clean my new block up but dont want to damage the cylinder walls at all. Is hot dipping recommended or should I just use good old elbow grease?
1989 944 Turbo Cup Replica
PCA Space Coast Region #44
Old 11-25-2006, 11:27 AM
Hot soapy water (use ivory liquid) and use a blow gun to dry out the passages.
Good luck, George Beuselinck
Old 11-25-2006, 11:39 AM
s928s's Avatar
I used a pressure washer, paint brushes, tooth brushes and several other tools and a good degreaser. let it soak for a while. Blow out all of the oil passages
autowerks9
PCA SINCE 1991, REISENTOTER
1982 EURO 928S 320HP MEDIORMETALIC/BURG.
1987 944S- GT3 BODY CONVErSION RED/BLACK( sold )
2003 MERCEDES E500 Sport "Einfarbig"
Old 11-25-2006, 12:26 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Took it to the car wash and pressure washed it.
Similar procedure to davids.....
As long as you blow it out well.............
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-25-2006, 01:00 PM
BoxxerSix's Avatar
Yea if you hot tank your block in the same chemical used for regular cast iron blocks, you won't have a block left. The acid will eat the aluminum to nothing. There are chemicals(acids) that are fine for aluminum, usually referred to as cold tanks, but something as large as a block i'd avoid it.
Most good machine shops have a hot bath. It's a machine that you place parts on a vertical rotissery. Door is closed and the part(s) are pressure washed in a mild chemical degreaser solution, but at ~300 degrees F to dissolve any oil/grease residues. Remove and rinse/blowdry and you're left with a very clean part. Usually only used on heads and aluminum parts, or stuff too fragile for harsh chemicals....but most are more than large enough to accomodate a 944 block. Mine's big enough to fit a 928 block in it.
Adam Hennessy
Old 11-25-2006, 08:02 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Pressure washer and soap per Porsche recommendation for mine. Not sure what that procedure would do. I didn't want to run the risk of damaging my motor.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 11-25-2006, 10:43 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
I haven't done it with a porsche block, but my MO is to go to a car wash that has the degreaser option. Bring a few cans of Foamy engine Brite, a couple of stiff nylon brushes, old towels, a milk crate, and some WD40. Wear grungy clothes, this gets messy. Spray and scrub the block on the crate using the engine brite. Drop in a few quarters and Pressure it all down. Dry with an old towel and/ or leave it in the sun for a while. Spray the WD40 on any exposed metal you don't want to rust right away.
It is also a good idea to scrub off an engine before you do major work. It helps you see what you are doing and minimizes mess.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 11-27-2006, 08:14 AM
Send a message via AIM to hpaulb
Use the engine stand. They can always be disasembled for pick or minivan carting. There cheap and so helpfull.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 11-28-2006, 11:42 AM
