924S Door Hinge Repair
Folks,
Last week, I noticed that the driver's side door ('87 924S) was striking the latch pin much too hard. The door was hard to close.
After playing with the hinges, I finally noticed that the upper hinge has started to tear out of the A-Pillar and is allowing the door to sag under its own weight. (mea culpa, mea culpa - no more resting my arm on the door to get my middle-aged 230 lbs down on the seat!
Anyway, what I'm planning is to take the door completely off, carefully protecting the fender and visible parts of the A-Pillar, and carefully and slowly spotting the tear back together with a MIG welder. I'll clean the paint off before starting and then cover the weld with guards red paint or something close.
It will pass with the door closed, but the car will be even less a concours candidate than it is now. (not even close!)
Anybody had/fixed this problem? Any thoughts on my idea?
Thanks,
924SBob (the other one)
Old 12-04-2006, 11:21 AM
Stumped ya!
Hmmmm. First time I've stumped the community.
I'll let you know what happens.
924SBob
Old 12-05-2006, 03:11 PM
SoCal Driver's Avatar
Sounds like you got it all figured out. Take pictures and make a procedure out of it.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-05-2006, 03:16 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Weld on pillar
Unless you are a particularly good welder, consider having a pro run the bead(s)/Spots. A little grinding and some fill work will go a long way to minimizing the cosmetics impact.
A pro could do it quickly, lessening the paint discoloration in the area. Welding on sheet metal is tricky. A pic would be nice to see what exactly you are dealing with.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 12-05-2006, 11:19 PM
Send a message via AIM to hpaulb
While on the subject, my door seems to work just fine except it is really hard to press the latch to open. Hard for me and even harder for my 10 year old. Is this common? How to fix? Both sides.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 12-06-2006, 10:18 AM
I've had two 924's and both had the drivers side door hinge come loose. Both were welded, one not too successfully. The hinge is thick and the sheet metal of the pillar is thin. It aint as easy as it looks. If it comes loose again I'm going to fashion a backer plate to stick in the pillar.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 12-06-2006, 05:05 PM
Progress
I went to a local body shop and they are going to do the welding and a simple paint coverup. It's scheduled for next week. I'll try to get some pictures to post before, during, and after.
The tech agrees with JonA. We'll see how it works out.
924SBob
Old 12-07-2006, 07:53 PM
Success
My local body shop did the welding. I'm going to get some Guards Red touch up paint to finish the job. Seems to work just fine. Time will tell.
I'll get a picture and post it as a reply.
Thanks for all the advice and support.
Old 12-14-2006, 07:49 AM
Bringing the Shine!
stephenwz968's Avatar
I had to do the same thing-a local shop did the welding/touchup. It's not perfect, but the door works great, and really only I know what's there.
1995 968 Cab Speed Yellow/Black
1992 968 Coupe Turquoise/Cashmere
Old 12-14-2006, 07:59 AM
Not pretty, but it works!
Here's a quickie photo of the hinge repair. Looks awful, but the door works just fine. We'll see how it holds up.
This welding calls for experience. I recommend a pro unless you're a pretty decent welder.
Old 12-15-2006, 08:17 AM
