RadioDjKev's Avatar
Send a message via AIM to RadioDjKev Send a message via Yahoo to RadioDjKev
Porsche Crest Manual Transmission Fluid change 944
Hey Guys and Girls. (Are there really any Girls in here?)
What is the best oil for my manual trans on a 1983 Porsche 944?
Is there a synthetic out there?
What is the procedure?
Thank you, www.KevinGerard.com
1979 Porsche 928 5 speed
1983 Porsche 944 5 speed
Old 11-28-2006, 11:02 PM
RadioDjKev's Avatar
www.KevinGerard.com
2005 Husqvarna TC250
1999 Porsche 986 Boxster 5 speed manual 90k. (as of April 2008)
Old 11-28-2006, 11:16 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
TransFluid
I used Mobil 1 75w/90
Others swear by Redline.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 11-28-2006, 11:35 PM
adrian jaye's Avatar
I use what is recomended in the book
never failed me so far
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 11-29-2006, 02:37 AM
Eldorado's Avatar
mobil 1 80w90 in mine... works great..
redline is another good choice.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 11-29-2006, 05:45 AM
Mein Gott!
Panzer909's Avatar
SWEPCO 201
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 11-29-2006, 06:03 AM
ERAU944's Avatar
Send a message via AIM to ERAU944
swepco is good - i've used it and it does work wonders for the 1-2 shift
i have mobil 1 80w 90 in my 944 right now, and due to availability will probably put that in the 951 as well.
i can't easily get redline OR swepco, but mobil 1 is easy to get at wal-mart, and it works
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 11-29-2006, 07:31 AM
Not Special
How difficult is the fluid change? I do lots of stuff to my car (oil change doesn't bug me much), but mucking around with the transmission worries me a little. Plus, how do you get the fluid into the transmission...there's not a pour spout like in the engine for oil!
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen
Former: 1985/1 Porsche 944 - Graphite/Black
Old 11-29-2006, 07:56 AM
ERAU944's Avatar
Arrow
ah, the new fluid is the fun part. it's not too difficult to change, you need a 17mm allen/hex wrench (i believe thats the size), and you DEFINITELY MUST open the top plug first, that way if the bottom plug is stuck, you can at least suck the fluid out and change it, otherwise enjoy removing the transmission and turning it upside down to change the oil. then remove the bottom to drain. after that, reinstall the bottom plug, and fill the transmission with fluid until it's about 1/4" from the top hole, and you're done. double check the quantity in the manual, it's been awhile since i did it. the quantity will also vary a little if you have a transmission gear oil cooler, and you may not be able to drain that completely unless you have the transmission off the car. the installation can be tricky, i used a little bit of hose fitted onto the gear oil cap, and kind of worked the bottle up in the area between the transmission and the body to make it higher than the hole. take your time and be patient, and you'll be able to do it without spilling (much) fluid. also, the old fluid will smell like garbage, because there is sulfur in it... that is normal.
have fun!
Old 11-29-2006, 08:02 AM
liljon's924S's Avatar
Mobil 1 synthetic, Hey isn't mobil 1 Porsche Approved also? Or is that just for motor oil?
"I couldn't find the sports car of my dreams, so I built it myself."
-Dr. Ferdinand Porsche
'87 924S Guards Red, 944 turbo bars, 220lb. springs, Restoration Project even though its and original, 72,000 mile car
'93 325is Red, aftermarket rims, pirelli tires, 95,000 miles
Old 11-29-2006, 02:15 PM
RadioDjKev's Avatar
Hey everyone Thanks! Nice to hear all this from Porsche owners!
I did not want to trust a 24 year old manual..
My transmission sounds and shift perfect!
I will go with the Modil 1 Being an x motocross racer we used modil 1 80w90 in my KTM 380sx gear box.
I will check that Walmart tip.
www.KevinGerard.com
Old 11-29-2006, 02:42 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
If you have a harbor freight nearby, they used to have a small hand pump that will pump it in. The pump will also suck out the old oil if you can't get the bottom drain plug out. Don't sweat this job too much it's just as easy as changing engine oil if you have that pump.
And yes, we do have a few ladies that stop by occasionally.
Good luck with your lube change.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 11-29-2006, 03:35 PM
RadioDjKev's Avatar
Yes I have the pump. Thanks for your help.
Kevin
www.KevinGerard.com
Old 11-29-2006, 04:11 PM
winter-hater club member
nynor's Avatar
redline MTF went into my '83. the transaxle was smoother and shifted more fluidly. i recommend it.
"COOL PRIUS!" - Nobody Ever
Old 11-29-2006, 05:12 PM
Parrothead member
VINMAN's Avatar
Castrol 80/90w works just fine for me.
Vinny
Old 11-30-2006, 06:22 AM
Not Special
Hm...when I think of allen wrench I think of something very different from the wrench I see in the pelican parts catalog...someone want to straighten me out?!
Old 11-30-2006, 09:21 PM
Eldorado's Avatar
what do you see?
Kyle
Old 11-30-2006, 09:22 PM
Not Special
Part PEL-TOL-P222. Only thing I've found yet that's 17mm
Old 11-30-2006, 09:29 PM
BoxxerSix's Avatar
if you don't have a 17mm heax tool and you're in a pinch go to a hardware store and pich up a grade 9.8 or higher 17mm hex head bolt 2.5" long and 3 9.8 grade nuts of the same thread as the bolt. spin all the nuts onto the threads of the bolt until they all bottom out, jamb them together really tight (heck use loctight if you have it) using a couple wrenches.
use the bolt head as the "hex" for the drain/fill plugs and just use a wrench on the nut closest to the bolt head for the wrench. if they're jambed tight enough the tool will work fine. cheap $3 tool if you need it in a hurry.......or if your $22 hex tool suddenly snaps off for no damn reason
Adam Hennessy
Old 11-30-2006, 09:58 PM
Not Special
Thanks guys. I just realized my problem - I have hex KEYS, not hex wrenches. I've got about a week before I'm planning to do the tranny fluid so I probably could make it to the store to get a wrench/socket if I wanted to.
Old 11-30-2006, 10:23 PM
