Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Dumb 924S Questions
On an 87 924s: (or similar)
What do those 4 switches (ok 3 switches and 1 blank slot) on the console just aft of the shifter do? I cannot tell from looking at them and turning them on and off doesn't seem to have any effect. ( Somewhere in Bulgaria a lamp may be blinking for all I can tell)
When you look at the relay panel above the fusebox, are the two left spaces supposed to be empty? or... Is that the reason I don't have any working headlights?
Is the Aux Fuse panel supposed to be fastened to anything or is the swinging in the breeze a new way for the wires to cool themselves?
Thx,
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 12-10-2006, 06:50 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
the first switch closest to the driver is the power mirror select switch
another is for the rear wiper, the one all the way towards the passengers side
the second towards the passenger side is headlight washers
the third switch to the right should be blank (i don't know what would go there)
this info comes from my father's bone stock '83 944 with 30k miles on it.
*note* the previous owners of your car may have added switches for who-knows-what that fit into those holes, i'm sure auto parts stores sell similar switches that would not have pictures on them but are of universal application
good luck! if you look close, you may be able to see outlines where the white paint was on the switches. i can see the outlines on my '84
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 12-10-2006, 07:48 PM
