Another whats this plug go to question
Im in the middle of dropping the fans down to get a closer look at a small coolant leak. i cant see it, but its dripping down the drivers side edge of the fan casing.
while removing the airbox i saw this plug next to the throttle body. its not connected to anything and it has what looks like two female ends in it. where it looks like it should go on the engine there is already a plug there. http://i37.photobucket.com/albums/e5...03843_mark.jpg |
That goes to the squeal suspension module on your torque tube.............
Jon |
LMAO! this bulletin board is so much more fun than the other i use for work!!! you guys crack me up. :D
muffler bearing electrical connection
but i dont have any muffler problems at the moment. remember you guys fixed those for me in september?! :)
That is the FC908 option connector. Alot of cars didnt come with it because the increased load of the flux capacitor kills the alterantors prematurely.
I actually think that connector is supposed to be disconnected and not connected to anything. Seriously. |
Kevin, please tell me you caught what i said :p
On my PC that plug looks blue, if so it could be the engine temp sensor. Located in front of the TB on the block. There is another one behind the TB on the block as well, same side.
Dal |
LOL i did kyle!!! sent it right back to you! guess YOU didnt catch it in the reply! ;)
thanks Dal, and Jon, i'll have another look there soon. |
d'oh!
| All times are GMT -8. The time now is 12:50 AM. |
