valve springs 2.5L
can 2.5l 85.5 944 turbo valve springs work with non turbo 944 85.5 2.5l?
there is a $23.00 difference |
Should work just fine. I believe that one just has a little more spring tension than the other does. As long as you use the whole matched set you'll be fine.
'91 Jeep Cherokee 4.0L HO - Daily driver '83 Callaway 944 2.5L turbo - Soon to be daily driver '83 Porsche 944 NA - sold '78 Porsche 924 NA- RIP '89 Porsche 944 S2 - Parted Looking for a nice 944S for a daily driver. |
According to Porsche, the inner springs are the same and the turbo outer springs are 20% stiffer than the na outer springs.
If you want the proper springs, we have several sets in stock.
Good luck, George Beuselinck |
