Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
Send a message via AIM to hpaulb
Question Wire run
Thought I'd throw out a thread as there hasn't been a new posting in 2 weeks???
I was working on my heater cable. Put the center console back together and no lights on my clock and oil pressure Gage but the Gages themselves work, At the same time I noticed my interior lights don't work with the door switch either side. OK manually though. Anyone know if the wire run is together or common at any point?
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
03 Altima Tin box
05 Pontiac Sunfire, 64 VW dirt buggy
Old 12-15-2006, 07:08 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Greasy Member
many944s's Avatar
Not exactly sure.
Do you have the circuit diagrams?
If not, PM me with your email address and I will send you the diagrams, they should help you find any common points that could cause the problem.
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 12-15-2006, 09:34 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Granite 944's Avatar
Re: Wire run
The real question you should be asking, is, OH OH, I didn't get it all back together properly, and should I remove the console again, and recheck all I've done, including changing those OLD bulbs, and check connectors, grounds, look for corrrosion spots and ect, ect.
I'm assuming, these things worked before you took the console apart? If even if they did, you STILL need to do these above mentioned things. Good luck!!
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 12-15-2006, 05:41 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
I have the diagrams so I have the common points but they don't seem to indicate how it is run of somthing common between the dash and door switch connection.
Ya, I probable didn't notice a broken conection. Did fix one while assembling but what usually happens is another breaks while fitting it back together. Another on the list for winter think.
98 BMW 740i
03 Altima Tin box
Old 12-19-2006, 07:09 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
