thoen's Avatar
What is the header bolt size?
hi,
i am ready to put on the powder coated header done by John TNT25169
http://forums.pelicanparts.com/uploads9/Powder+Coated+Headers1167176243.jpg
and i would like to know the bolt sizes so that i can be prepared for the replacement.
thanks!
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Old 01-07-2007, 10:14 AM
TNT25169's Avatar
Send a message via AIM to TNT25169
You should have said something, I would have sent you the bolts, they are somewhere in my garage now...
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 01-07-2007, 10:52 AM
thoen's Avatar
hi,
i did. i emailed you just after I received them. I can buy new ones if i know the exact size. no problem either way.
thanks.
Old 01-07-2007, 02:48 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Are you looking for the studs or nuts. I think they are special material but I'm not certain of that. Here are the specs.
studs.....999-062-044-02 M8 x 30
nuts .....999-084-052-02 M8
washer..928-111-181-00
Hope that helps
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-07-2007, 03:17 PM
thoen's Avatar
thanks!!
Old 01-07-2007, 03:21 PM
TNT25169's Avatar
Hmmmm, I never got that email, sorry about that.
www.apartabove.com
Old 01-07-2007, 03:51 PM
TNT25169's Avatar
Ahhh, you asked for sizes in the email, not for the actuall bolts and nuts. It must have been a late night when I read that, I apologize again.
www.apartabove.com
Old 01-07-2007, 03:52 PM
thoen's Avatar
i read that it's good to replace these items. actually, from what i see, i only need to replace the nuts and spacers.
e
Old 01-07-2007, 04:14 PM
