-   -   how to modify a 944 engine???? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/321003-how-modify-944-engine.html)
fabiraning944 01-01-2007 06:44 PM
Alina post deleted -Z-man.
Techno Duck 01-01-2007 06:59 PM
If you can post the any of the charts after you put in the cam i would like to see them.
I am considering a cam from JME which should net similar horsepower, roughly 12-18hp. I am really interested in seeing how it changes the power band from stock.
fabiraning944 01-01-2007 07:21 PM
dally_de 01-02-2007 12:43 AM
what cam would be good for a n/a 944 85.5 ,120 kw ????have any suggestion's???
Tam Lin 01-02-2007 03:26 AM
Originally posted by Schumi
I have always wondered the exact specs on the 2.5L cam.
Like these?http://forums.pelicanparts.com/uploa...1167740778.jpg
http://forums.pelicanparts.com/uploa...1167740806.jpg
Schumi 01-02-2007 06:42 AM
good charts, thanks.
Exactly what are the bottom two cams though? I guess the R cam was for factory race cars? Which ones?
Tam Lin 01-02-2007 07:48 AM
Good question: I've been looking for them in PET catalogues without much success.
My take on the more-power-in-944-N/A scenario is to build an 8v 3 liter, because you get, with more or less off-the shelf parts, extra torque without the complication of the 16v head.
A straight 16V 3L swap is unattractive, because:
- the 3L 16V 944S2/968 need different engine loom electrics
- the 16V head adds weight
- the 16V head also does not breathe that well. Lots of development work in England done by Colin Belton, who owns a good Indy shop called Neinmeister, on a throttle body intake for a 968, revealed that the problem to more power wasn't the intake, but in the head).
If this proves tricky (e.g. doing a custom chip might get expensive for the gains), I'll just drop in a 2.7 into my 924s and be happy. The thing has been on such a diet that even the ancient 2.5 in it moves it along quite nicely...
Gremlin85 01-03-2007 02:17 PM
How exactly does the 16V not breathe that well??? I thought thats why there are the 4 valves per cylinder was to increase air flow...? SO, your saying uping displacement on a basic 8V to 3.0L is better for torque than the 16v stock?
If this is so, I'd be in bore-mode and in heaven!
speedracing944 01-03-2007 03:44 PM
you could always remove the balance shaft belt and gain 7 hp.
Your engine may shake to death.
I may just try this during my next belt tension. Remove the balance shaft belt and drive around the block. I would also like to see how much the 2.5 shakes.
Speedy:)
fabiraning944 01-03-2007 04:06 PM
Tam Lin 01-04-2007 12:20 AM
Remember that these were very early 16Vs. If you compare like for like, i.e. 944S 16V vs. 944 8V, you'd have to be an optimist to feel that the stock 16V was much more powerful: maybe at the very top end, but the torque curve Porsche would have us believe for the 16V always looked fake in terms of the slower 0-60 times all the magazines got. The 944S2, and the 968 were better, but anyone who believes a stock 968 makes the 240 bhp quoted in Europe by Porsche is seriously deluding themselves. Explains why a 964 always feels much quicker, yet on paper should have only an extra 10 bhp or so, and more weight.
The technical gubbins are a bit over my head, but apparently, the 16V intake valves are a bit large & not optimally located for the cylinder scavenging the cam timing allows, so port charge-velocity is what limits power even if you add throttle bodies and mapped fuel injection. Which presumably is the reason why forced induction works so well on these engines.
Another indicator is that a number of Porsche engineers consider the 2.7 8V to be the best modern 4 cylinder engine Porsche has produced: on the face of it an odd comment to make in the hierarchy of the water-cooled series.
This time next year, I should be able to prove/disprove the effectiveness of a 3L 8V ;) . But I still have some lightening of the 924S to do before I play around with the engine, the suspension and braking I'm now happy with.
Gremlin85 01-04-2007 06:31 AM
I will wait with much anticipation on the 3L 8V. If it goes the way you are expecting/saying then I will def. up the displacement to 3L in mine and I'm sure there would be many followers.
Has anyone ever done anything like this before on the 8V?
::excited::
surfdog4 01-04-2007 12:53 PM
so did Alina post under two different names on this thread?
944 Ecology 01-04-2007 01:36 PM
Two to what power?
Z-man 01-04-2007 03:52 PM
fabiraning944 and war944S2 were both Alina. Funny part was when she was answering herself.
dally_de's IP is different enough from the other Alina IP's...
-Z-man.
surfdog4 01-04-2007 05:20 PM
i would have bet that dally_de was alina too....i still don't get why they would want to constantly invade this board..oh well i guess it keeps you on your toes, Z-MAN!!
dally_de 01-05-2007 08:36 AM
ok guy's..i'm not from US so i do not know what do u mean with ''Alina''
pls explain...and do not be rude..i am new on this forum.
thank u..
Z-man 01-05-2007 09:42 AM
dally_de - Alina was a person who originally came on this website and started trash-talking and insulting everyone. Her English wasn't very good because it was a second language, just like you.
Alina kept coming back after being banned - again and again under different names. So when people here see a new member whose English isn't that good, they assume it is Alina again.
I am sorry that some here confused you with Alina - while your English may not be perfect, you are more than welcome to contribute to this board. And nobody is saying that you are like Alina - you are NOT rude and angry at everyone, so please don't think people here feel that way...
Welcome, and I hope you stick around. We really are a nice bunch of Porsche nuts, after all!
-Z-man, Pelican Parts BBS Admin.
dally_de 01-06-2007 01:05 AM
ok-got it...
well i'm not alina...and i do not want to be taken like that. i love my 944 and can't sell it and buy a turbo...that is way i have posted here for some suggestion and opinion..
also here in my country r not that many 944...dont know if r more then 20 in a resonably shape ...i love this car and also love engineering..
thank u all...
p.s: i like this forum.
CJFusco 01-10-2007 07:15 AM
Welcome to the forum.
