valve lifters, how do you inspect?
I've got everything ready to put back together on the cam tower but want to check the valve lifters before they go back in. The engine ran fine before disassembly, the repair is to cure an oil leak. How do you inspect the lifters? Two of them will compress when I push with my finger, the rest will not. Do I have a problem with these two?
A visit to Clark's Garage and a search on this site did not turn up any useful information.
Thanks,
Jon
Old 12-22-2006, 11:08 AM
p-talk's Avatar
Only way I know how to check them is listen - do they tick when it runs? Mine ticked for a few seconds when I changed the oil on startup until the pressure came back, that's it.
BTW, how hard to change the tower cover gasket, that'll be in my future . .
1984 Porsche 944 - Mathilda the needy
2010 Audi A4 Avant - daily driver
1990 Audi 200 Turbo Quattro Avant - recently wrecked, future uncertain . . .
Old 12-22-2006, 01:28 PM
Those two are suspect.
Try compressing it in a container of cleaning solvent until you cannot compress it.
Then compress it in a container of oil until you cannot compress it.
If you cannot compress it, then it it's good.
The internal ball check valve was just dirty and not seating properly.
If they don't hold oil and you can still compress them even after cleaning, replace them.,
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 12-22-2006, 02:23 PM
That Guy
Techno Duck's Avatar
What i did with a friend was used a couple of spring clamps to compress the center (we used short bolts as stand offs). We let them sit a day or two and whichever ones had collapsed were considered bad. We replaced the collapsed ones with known good ones and the 'clack clack clack' on startup went away.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-22-2006, 04:37 PM
Thanks Guys, I'll try to flush out the 2 suspect lifters tomorrow and then soak in oil and see if they will stay un-collapsed.
This engine had no valve noise before disassembly, strange.
I also found the #2 injector elec connector most of the way off when I removed the rail. I don't know if it was making the connection or not but I'm curious to see if performance improves when it runs again.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 12-22-2006, 05:59 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
This is how I do it as well.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 12-22-2006, 06:38 PM
