strong exhaust smell
OK its running fine but it has a strong exhaust smell.
It has a catalytic converter (unknown condition) and a OEM muffler. Would installing a new catalytic converter take away the smell, or what else could it be? 1988 non turbo 8v
Lowell 1988 944 Red Project car (Now daily driver, Daughter's to school ride) 1983 944 Grey NEW Project car http://www.pelicanparts.com/gallery/tnporsche |
Hatch seal....if you smell it in the car...
-2002.5 GTI VR6 24V 6SPD -Kalahari Beige 89 Porsche 944S2 -87 VW GTI 1.8 16v -2007 Ford PIMP(free)star ...company car.... -1999.5 Jetta VR6 |
rear hatch seal, rear hatch adjustment pins, carbon canister, shifter boot insulation (below the leather boot)
1995 993 C2 |
oops failed to mention outside the car not inside.
I'm with Bill
If the cat is trashed you will have a strong sulpher smell. (most of the time)
Could be running rich, that smells...............yucky. Have you switched brands of gas or run gas from a discount place?
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Is it possible to run ok , but rich?
I'll try high test gas also
Sure, it's quite possible to run rich but okay. Oversimplified, the oxygen sensor tells the computer how to set the fuel mixture, so it could be that. If it's not plugged in, the car will run but run rich, so make sure the oxygen sensor is plugged in and has good connections. Pull one of the spark plugs and check the color. If it's black, then the mixture is rich and the problem is before the cat. If it's tan, then check out your catalytic converter.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
I'll check that in the morning thanks,
Does the computer send a check engine (red excalamation) for the O2 sensor? Come to think of it what all does trip the red light?
There are many things that trip the light but the oxygen sensor is not one of them. I don't know what the complete list is, but it's for critical things like brake fluid, low oil level, emergency brake on, etc. Sorry I am not more help on the list...maybe someone else will know or know where to find the complete list.
what's your gas mileage like? if it's below 20 for 'normal' mixed street and highway driving you probably need to change the O2 sensor. i have a strong smell in my car, and i believe it's because of the hatch seal. weirdly, it only happens when i have the windows open, worse when they're just cracked, but not at all with the windows shut. my car has no cat, and the smell isn't bad (at least i dont think so, but i love the smell of just about any exhaust). with the cat my car smells like normal exhaust from any other car.
i'll second the charcoal cannister theory, check under the drivers side front fender and see if the smell is there. if the smell is raw gas it's most likely the charcoal cannister. if it's exhaust then you may have an issue.
Mike - CFI, A&P Mechanic w/ I.A., Service Manager at Fuel Injector Clinic '88 951S - zermatt silber/black - staying stock. purchased in 11-2006 '84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001 '14 Ford Focus ST - tangerine scream/black '83 944 - zermatt silber/black - Dad's 40k mile time capsule. purchased in 09-1998 @ 18k |
My car does the same thing, usually when i get on it a little, the trunk seal may be bbad, but I dont think the exhaust should be that strong, I am trying to change the O2, but so far I cant get it out.
1987 Porsche 944 1971 Porsche 911E..(It went home,Germany!) 1969 Porsche 912 1964 Porsche 356c..(roller) 1988 Porsche 924S (PARTS CAR) |
I did put a new O2, now it surges, so i unplugged it... my problem is elsewhere.
Banned
Lexluther, you probably have a vacuum leak somewhere.
BTW, you should check out OT...you could do battle with Superman... |
Trying to work for parts!
If you smell exhaust when your driving with the window down or cracked some, it is the rear hatch seal or pins. It's common on these cars. Adjust the hatch pins & see if the hatch seal is seperated. Rennbay has new hatch pins that are made by someone on rennlist. I've got a set and they make a huge difference.
86 Metallic Grey 85.5 Metallic graphite - Gone |
Senior Member
Right you are. If you don't get this fixed, I'll smell you coming. A way-rich mixture will overwork a CAT, and cause a sulphur, rotten-egg smell. Plain ol' unburned fuel smell might very well be the evaporative emissions system (charcoal cannister).
Man of Carbon Fiber (stronger than steel) |
Thread Tools | |
Rate This Thread | |
