Brake Height
Is there any way to adjust the eight of the brake. When I want to heel toe it seems to be a bit high making it hard for me to get to the gas pedal.
Dan
1988 Turbo S (Red)
2005 Acura TL Black [Totaled]
2008 Grand Cherokee Overland (Black)
http://i25.photobucket.com/albums/c9...S/dsc_0437.jpg
Old 12-30-2006, 07:21 AM
Don't think you can easily adjust brake height. I just saw this adjustable gas pedal height for that problem thoe.
http://rennline.com/product.php/sid/11/auto/Porsche/prodid/115
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 12-30-2006, 11:19 AM
You can adjust the length of the pushrod for the master cylinder. Don't adjust it too much or you may not be able to get enough braking power when you need it most.
Good luck, George Beuselinck
Old 12-30-2006, 11:59 AM
How can I adjust the pushrod?
Dan
1988 Turbo S (Red)
Old 12-30-2006, 01:20 PM
