ATE Super Blue Brake Fluid
I tried searching the archives, but a quick look didn't reveal the answer I was looking for. My question is, are there any compatibility issues with ATE Super Blue Brake Fluid and ordinary DOT3/4 fluid? Do lines have to be drained and flushed with alcohol?
Thanks, Ed
'87 924S |
Mein Gott!
You don't need to flush with alcohol.
Simply flush out the older fluid using the conventional method(s) until you see the distinct dark blue color come out of the bleeder on the calipers. It is not a good idea to mix different fluid types, but a typical brake bleed isn't that long of a job.
Johnny 1987 944S 1984 944 (R.I.P.) 1972 Triumph TR6 - 100% trouble free between breakdowns 2003 BMW 325xi |
I just bled my brakes and used the super blue fluid about a month ago. The only problem I have now is that the pedal travel is slightly longer than what it was before I bled the lines... anybody know how to fix this? Other than that its great!
"I couldn't find the sports car of my dreams, so I built it myself." -Dr. Ferdinand Porsche '87 924S Guards Red, 944 turbo bars, 220lb. springs, Restoration Project even though its and original, 72,000 mile car '93 325is Red, aftermarket rims, pirelli tires, 95,000 miles |
Mein Gott!
Sounds like there's still some air in the system. A good brake bleed will give you a short "solid" pedal feel.
meister member
Is the super blue DOT3, DOT4, DOT5? 3 and 4 can be mixed but it is not capatable with DOT5.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
That Guy
ATE SuperBlue is DOT4
One can is enough to flush the entire system. However i would just get two cans as its always good to have extra around so you can bleed the air out. Especially important if you do any type of racing.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
My resevoir had little tiny specs in it, I got those out with a bent small spoon and then flushed about a cup of fresh DOT 4 through it with a power bleeder. Then I poured and bleed the system with the Super Blue.
I have front and rear 4 piston Brembos, with a hydraulic hand brake and a split front/ rear independent brake system... everything runs on SuperBlue and I love it!!! |
