three holes for Air Oil separator, Oil filler?
I just want to make sure everythings okay here...
i removed the AOS oil filler neck there are two ports on the unit, one upper one lower, now on the engine block, there is a third hole next to the lower hole, it is behind the hole that lines up with the filler neck. does anything go in there? i want to make sure i didnt loose anything. i cant see anything that lines up with that hole on teh filler neck at the bottom....
1995 993 C2 |
You are good, there are only two associated with the AOS. I am not sure what that hole is for but on mine, there was nothing in there.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
shew close call. why does pelican show that you need "Seal - Oil Separator/Filler to Engine, Lower, 2 required per car, 924S/944 all, 999-701-661-40-M100"
TWO per car?? am i putting two of the lower ones on the lower part? one more thing, the filler neck sliped off the work bench when i was cleaning it, there was a small piece of plastic broken off the bottom lip, just ahead of the lower gasket, right on the lip, so a small part of the lower gasket is exposed slightly where it mates with the engine, its a small chip do i need to add an oil filler neck to the list?
1995 993 C2 Last edited by EMBPilot; 01-15-2007 at 08:26 PM.. |
Kevin,
When I ordered my seals they sent me 2 large ones and 1 small one. That is what the parts book told them. I only used one big one on the lower and one small on the upper. Are you rebuilding the engine? Could the other hole be for the ref sensor to go down? I can't answer your plastic chip prob.
peter 1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee" 1987 944S Alpine White, Ice Shark Lights "Desert Ghost" 2015 Charger R/T Road & Track |
thanks Pete! i think the small chip may be okay, since its on the front of the lip, the gasket should keep the oil back, since the sides and back part of the plastic lower rim are OK.
1995 993 C2 |
I only see one o-ring on mine so I'm not sure why Pelican calls for two. The o-ring makes the seal so a small chip there shouldn't hurt but I know for sure you don't want an air leak there. I have an extra one of those if you want it...just let me know.
1995 993 C2 |
Burn the fire.
Replace.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
That Guy
That will leak, replace it. Its possible it wont..but if it does you will be taking the intake manifold off again.
The reason they probably send two large seals and one small one is they changed the size of the o-rings on engines made after a certain year. I think most engines made after '83 got the two different sized o-rings, i have the engine codes in a parts book at home. Make sure the filler that Tom has is the correct one for your engine.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 01-16-2007 at 03:50 AM.. |
